patriziale8 Dec 2017 18:27Hello everyone, I am currently looking into how to protect my Malm furniture from water damage. Since these pieces are made of particleboard with a laminated surface, I am unsure how sensitive the edges and the feet actually are. My question is: What specific steps and precautions are effective to protect Malm furniture from water damage without affecting its appearance? Are there any particular care or protective products that are especially recommended, or are structural modifications (e.g., felt pads, protective mats) necessary? I look forward to your experiences and tips, preferably with explanations of why certain measures are useful.
Hello patriziale, your concern is completely understandable, as Malm furniture is indeed sensitive to moisture since it is made of particleboard with a thin surface coating.
To protect your furniture, I recommend several measures:
1. Do not place the furniture directly on damp floors; definitely use protective pads or glides made of plastic or felt, which can also significantly reduce swelling at the edges.
2. Avoid standing water, so check whether, for example, plant trays are waterproof, or protect the furniture surface with transparent plastic mats that are hardly noticeable visually.
3. For maintenance, special wood care oils or waxes are currently not recommended for laminated surfaces. A mild cleaning agent is sufficient, but any moisture should be wiped off immediately.
4. Regularly inspect edges and cutouts on the furniture for damage. Even the smallest defects can allow water to enter, causing the particleboard to swell.
This approach protects your furniture much better than just hoping the laminate will repel all moisture. If you have any further questions, I’m happy to help.
patriziale8 Dec 2017 19:03sanpar58 schrieb:
A mild cleaning agent is sufficient, but any moisture should be removed immediately.Thank you for the detailed advice! I am considering whether it makes sense to apply some kind of sealant specifically to the edges—perhaps clear varnish or a wood preservative. Do you or anyone else have experience with this? I would prefer not to be too aggressive in order to avoid visibly or noticeably altering the surface. On the other hand, I am concerned that the edges on Malm furniture might be the most vulnerable spots. Are there any practical recommendations?
Hello patriziale,
regarding your idea of additional edge sealing, here are some important tips based on my experience:
1. The edges of Malm furniture are indeed particularly vulnerable because the laminate often only overlaps there or is heat-sealed. This means moisture can quickly penetrate if the edge is damaged.
2. Clear sealing (e.g., with clear varnish) can generally help, but caution is advised: many varnishes do not adhere well to laminate or particleboard edges and can crack or peel off easily with movement.
3. Alternatively, I like to use special edge protection profiles made of plastic or transparent silicone. These are flexible and provide a lasting seal for the edges.
4. If you want to paint, make sure to prepare the surface carefully with very fine sandpaper (e.g., grit 400) and use a product specifically designed for melamine-coated or laminated surfaces.
In summary:
- Regular inspection of the edges
- Edge protection profiles or silicone sealing as the best options
- Be careful when using varnishes; follow product recommendations and test on an inconspicuous spot if possible.
If you like, I can also provide sources for obtaining edge protection profiles.
In summary:
Hi 🙂
I completely agree with the previous comments and would like to add that, especially with IKEA Malm furniture, the base area often tends to be a weak spot.
Using plastic or felt glides under the legs really helps—preferably those with a water-repellent underside. This not only protects the floor but also keeps the furniture legs dry and prevents them from absorbing moisture.
One more tip: If a glass of water spills nearby, don’t wait for it to dry on its own—better to quickly soak it up with a dry cloth, as this makes a huge difference 🙂
Good luck!
Good luck!
patriziale schrieb:
Are there any practical recommendations?Hello, I would focus on care and protective products that are compatible with plastic and foil surfaces based on their ingredients. Many wood preservatives are more suited for solid wood and can damage the coating.
Nowadays, manufacturers also offer special sealants that can be applied in thin layers on laminate or foil-covered surfaces and provide some protection against moisture. You can search for these products at a hardware store or online using terms like “water-repellent laminate care” or “transparent furniture sealant.”
Additionally, good indoor air circulation and avoiding high humidity levels can also help keep the furniture in good condition for longer.
A small note: I once encountered a case where the furniture was placed close to a window — moisture from condensation on the glass affected the edges. So, check the surrounding environment as well!
