ᐅ How can I protect MALM furniture from moisture?
Created on: 27 Dec 2024 09:14
danzachary
I’m currently facing the challenge of how to best protect my Malm furniture—especially the dressers made from wood particle boards—from moisture. In our apartment, the humidity levels in winter can be quite high at times, and I want to prevent the furniture from swelling or showing damage along the edges.
I’ve considered using special sealants or varnishes but have also heard that some treatments might harm the material or alter its appearance. Do you have any tips or proven methods for effectively protecting MALM furniture from moisture while preserving the material?
What measures have you taken? Also, what about the placement of the furniture—for example, should it be kept away from sources of moisture, or is proper air circulation sufficient?
Looking forward to your experiences and recommendations!
Palenar
28 Dec 2024 13:04
danzachary schrieb:
Would something like this help?
And what do you think about using a clear coat as a surface sealant? Would that significantly change the appearance? Or could I possibly refresh a UV coating like the one IKEA uses?
The idea of using a protective film or a moisture-repellent cloth is very good and practical, especially if the furniture is placed near a window.
Regarding the clear coat question: Most IKEA furniture has a melamine or acrylic finish, which can be problematic if painted improperly. A clear coat changes the texture and sometimes the glossy or matte appearance. A UV coating like IKEA’s is applied industrially and is difficult to renew at home in the same way.
If you are open to experimenting and don’t mind testing the surface in an inconspicuous area, you can try a matte polyurethane clear coat – it is relatively durable and, if applied thinly, hardly alters the appearance.
Otherwise, the best method is prevention through careful placement and humidity control. Painting or sealing is more of a secondary step, mainly useful for small areas that need repair.
One more question: How often do you ventilate the bedroom? That can make a big difference in moisture buildup.
