I have a few Malm furniture pieces from IKEA at home that I would like to protect against moisture. Since the surface is occasionally exposed to slight humidity, I am wondering which measures are truly effective in preserving the material—especially the particleboard and surface coating—over the long term from swelling, discoloration, or mold growth.
Are there specific care products, sealants, or preventive solutions that have proven successful? How important are storage conditions in general, such as room climate, humidity levels, and distance from walls?
Maybe someone can also share relevant experiences with moisture protection for MDF or particleboard furniture.
I am looking forward to detailed tips and practical suggestions that are easy to apply for someone who is not a professional craftsman or furniture expert. Thanks in advance!
Regarding Malm furniture and moisture protection, I would like to add the following:
1. Malm furniture is mainly made of particleboard with a melamine coating, which offers little to no water resistance and can swell when exposed to moisture.
2. The most effective prevention is proper storage in a well-ventilated room with a humidity level between 40–60%.
3. For increased moisture exposure, such as in kitchens or basements, I recommend using electric dehumidifiers instead of chemical granulates, as they are more sustainable and efficient.
4. Protective measures applied in advance, such as sealing with clear polyurethane varnishes, can protect the surface from short-term wetness but require craftsmanship and alter the original appearance.
5. Commercially produced furniture films or protective mats can also serve as a barrier.
6. Regular maintenance and immediate removal of any liquids remain essential.
7. It is also recommended to keep a minimum distance of 2 to 3 cm (around 1 inch) from the wall to allow air circulation.
These points are based on material properties and moisture management.
PECLARISSA18 Nov 2021 12:36andre3 schrieb:
Polyurethane coatings can protect the surface from short-term moisture exposureI agree with that, but applying them requires some patience and a careful eye to avoid stickiness or an uneven gloss.
reneskil schrieb:
Are dehumidifiers really effective in small, mostly confined rooms?Absolutely! They make a lot of sense in small rooms with high humidity. You often notice quickly that the furniture “sweats” less and no longer feels so damp. I use electric models – of course, they’re not cheap, but they work well.
Additionally, houseplants like snake plants or spider plants can absorb some moisture – but they’re no substitute!
So: indoor climate is king, and when that’s right, furniture care becomes much easier. 🙂
I had the same problem with my MALM drawers that were placed against the wall, where it got quite damp during winter.
I usually keep my dehumidifier running continuously, especially during the heating season. Since then, no damage has occurred to the furniture.
I also put felt pads under the furniture legs to prevent any residual moisture from rising from the floor.
In my experience, a combination of good air circulation, careful handling of moisture, and these small aids works best.
Good luck!
reneskil schrieb:
How often should dehumidifiers be used?
Good luck!
