ᐅ How can I protect Malm furniture from dust?
Created on: 23 Aug 2022 10:17
Beja5
Beja5
23 Aug 2022 10:17
Hello everyone, I have some Malm furniture from IKEA, including dressers and nightstands, and I’ve noticed that dust accumulates very quickly, which makes cleaning quite difficult. My question is: How can I effectively protect Malm furniture from dust without damaging the surface or making it sticky? Are there any special cleaning products, covers, or home remedies that work particularly well? I would appreciate tips that provide long-term results while preserving the appearance of the furniture.
raulso
23 Aug 2022 11:03
Hey Beja5, I totally understand – these Malm furniture pieces really seem to attract dust, don’t they? 🙂 My advice is to regularly wipe them down with a microfiber cloth; that already makes a big difference. For extra protection, you can use furniture polish, but only very sparingly – otherwise, it gets sticky and attracts even more dust.
I’ve also had good results with antistatic sprays, which I once bought at a hardware store. They reduce static electricity and therefore the cling of dust. Of course, if you wipe it off gently afterward, it looks nice and clean.
Lastly, if you’re not using your furniture at the moment, sometimes a cover or a thin blanket can help, but be careful – dust tends to settle underneath after a while. So it’s best to ventilate and wipe regularly. Hope this helps you out! 🙂
LOGEMIN
23 Aug 2022 11:45
Hello Beja5,
Regarding your question about how to effectively protect Malm furniture from dust accumulation, here is a structured suggestion:
1. Regular cleaning: The most important measure is not to let dust settle for too long. A soft microfiber cloth works best, as it traps dust particles instead of just spreading them around.
2. Antistatic care products: There are special furniture care wipes or sprays with antistatic properties that reduce dust adhesion.
3. Avoid excessive chemicals: Oily polishes or waxes can attract dust if used too much. Therefore, it is better to apply them sparingly.
4. Control indoor climate: Dust often forms in connection with dry air. A humidifier can help reduce dust formation.
5. Preventive coverings: For infrequent use, a lightweight opaque protective cover or throw can help. However, dust can accumulate underneath if the area is not regularly aired and cleaned.
Summary: Effective dust protection requires a combination of regular cleaning, antistatic treatment, and controlled indoor climate.
If you wish, I can gladly provide recommendations for specific products.
angel
23 Aug 2022 12:32
Hello Beja5,
your question is very reasonable, especially since the smooth and matte surface of Malm furniture is quite sensitive.
raulso schrieb:
my tip is to regularly wipe it with a microfiber cloth—that already goes a long way.
Exactly, cleaning with a dry or slightly damp microfiber cloth is truly the best basic care; it binds the dust well and protects the surface.
What I would like to add: please avoid aggressive cleaners, especially those containing alcohol or ammonia, as they can damage the veneer of Malm furniture.
LOGEMIN schrieb:
A humidifier can help reduce dust build-up.
That is an important point! Especially in summer or when using air conditioning, the air often becomes dry, which promotes dust formation.
Regarding antistatic sprays: it is important to use them sparingly; otherwise, the surface attracts more dust than before.
Maybe you could also place your furniture slightly differently, for example, not directly under the window or in drafty areas, to reduce dust disturbances.
I hope this helps you!
gesar32
24 Aug 2022 09:11
For clarification:
Malm furniture is generally made from particleboard with a melamine coating. These surfaces are sensitive to excessive moisture and harsh cleaning agents. Therefore, it is important to always consider the surface integrity when taking protective measures.
Technically, dust accumulation results from the electrostatic charging of the surface and air movement in the room.
The following measures are objectively recommended:
- Cleaning with a dry microfiber cloth or a slightly damp cloth without cleaning agents.
- Use of products with antistatic properties specifically designed for plastic surfaces, applied in small amounts.
- Regular ventilation to keep the dust particle concentration in the room low.
- Use of an air purifier with a HEPA filter if allergies or significantly increased dust levels are present.
Please avoid waxes or polishes intended for wood and instead use care products specially formulated for plastics.
Conclusion: Effective protection can only be achieved through continuous and appropriate maintenance.
barda6
24 Aug 2022 10:04
A microfiber cloth and an anti-static spray are usually sufficient.
Even better: regularly dust furniture and avoid placing pieces in areas where dust is easily stirred up.
Do not use waxes or oils – they tend to attract more dust.
