ᐅ How can I prevent Malm beds from becoming unstable or wobbly over time?
Created on: 22 Nov 2015 18:03
KENTAN
I have a problem with my IKEA Malm beds, which after a few years have started to wobble. I don’t mean just slight movement, but actual creaking and noticeable instability, which is quite annoying in everyday use.
I’m wondering: how can Malm beds be prevented from wobbling after several years?
It’s important to me to find a sustainable solution that doesn’t require buying a new bed completely. Are there specific techniques, assembly methods, or additional materials (e.g., extra screws, glue, rubber pads) that you would recommend?
So far, I’ve tried tightening the screws, but that didn’t help for long.
I look forward to your tips and experiences!
CHENNE
22 Nov 2015 19:03
Connor schrieb:
Annoying, but often more effective than repeatedly tightening.
I agree.
In addition to reinforcing with metal brackets or plates, applying wood glue at the joints before tightening the screws can significantly extend the lifespan of the connection.
Important: After applying the glue, assemble immediately and clamp or avoid loading the parts for at least 24 hours.
Using metal washers with screws in particleboard can also help, as they distribute the load better and prevent pull-through.
CHRISTOP33
22 Nov 2015 19:12
Connor schrieb:
Screwing metal brackets under the sleeping surface might not look great, but it really stabilizes it.
Exactly, but hey, stability comes before appearance, at least for a bed that gets frequent use 🙂
I’ve installed small brackets myself, then simply painted over them or covered them with wood trim. It works perfectly, and the wobbling was gone.
Or, to put it casually: A little "workaround" has never harmed any piece of furniture! ;-)
GALEO4
22 Nov 2015 19:25
The discussion here is quite interesting, but honestly: When IKEA Malm beds start to wobble after a few years, it just shows that the construction is designed for short-term use.
Anyone who wants to use something like that seriously over the long term either has to keep making repairs or rebuild it professionally right from the start.
My view: It’s better to invest a bit more once and buy a truly solid bed, rather than constantly fiddling with screws and rubber buffers.
But if the goal is just to get a few more years out of it, then the tips here are quite helpful.
Teonon
22 Nov 2015 19:42
I simply applied double-sided tape to the feet of the bed. It holds surprisingly well and prevents it from sliding too much on laminate flooring.
Of course, this should only be done if you don’t plan to move the bed frequently. It noticeably reduces wobbling.
KENTAN
23 Nov 2015 09:14
GALEO4 schrieb:
If IKEA Malm beds start to wobble after a few years, it just shows that their design is intended for short-term use.
That may well be the case, but right now I am not considering buying a new bed. Therefore, I am looking for practical improvements for my current bed.
Thanks for the many constructive suggestions, especially the idea of using metal brackets and wood glue sounds interesting. I will try to combine both and report back on how it goes.
tu-se60
23 Nov 2015 10:05
Don’t forget to check the slat frame hangers as well.
If they become loose, this can also cause wobbling.
Sometimes it’s simply the contact between the bed and the floor.
