ᐅ How can I protect Ikea Platsa furniture from scratches caused by children?
Created on: 8 Mar 2021 08:37
U
UsdirkHello everyone, I have a very specific question: How can I effectively and permanently protect my Ikea Platsa furniture from scratches caused by children? The furniture has a quite smooth and sensitive surface that quickly gets damaged, especially when small children play around or climb on the cabinets. I am mainly interested in practical and proven methods that do not compromise the function or appearance of the furniture. Perhaps someone knows about low-maintenance protective products, stickers, films, or other tricks that have proven to be durable and childproof? I look forward to your tips and experiences!
JEREMIAH388 Mar 2021 10:14I can relate to your situation. As a father, I have experienced firsthand how quickly children can scratch furniture. A combination of protective film and clear boundaries worked well for us. It is also important to teach children to respect valuable furniture in a playful and positive way. I know this sounds easier said than done, but it helps in the long run.
Hey! Your question is really important! I would recommend films with a scratch-resistant surface; some are even transparent, so the appearance is preserved. Corner and edge protectors are also great as they prevent kids from scratching furniture with sharp edges. Just give it a try, it’s worth it!
stefangla8 Mar 2021 13:47I would like to provide a structured contribution here because this topic is often underestimated:
1. Material Analysis: The Ikea Platsa furniture uses a painted surface that is relatively sensitive. Aggressive cleaning agents should be avoided.
2. Protection Methods:
- Self-adhesive, transparent protective films made of PVC or polyurethane are well suited. They are abrasion-resistant and protect against scratches.
- Furniture edges and corners can be covered with foam or rubber bumpers to reduce mechanical damage.
- Furniture waxes or special furniture care products can slightly harden the surface but do not provide complete protection.
3. Application:
- Thoroughly clean and degrease the surface before applying the film.
- Films should be applied without bubbles.
4. Alternative:
- Position furniture so that the areas most prone to scratches are harder for children to reach.
Summary: The best solution is a combination of protective film and bumpers. There are also films specifically marketed for child-safe protection.
3. Application:
4. Alternative:
stefangla schrieb:
I’d like to provide a structured contribution here, as this topic is often underestimated: Thank you for this detailed overview! I’m interested to know which types of protective films are specifically recommended. Should one pay attention to particular brands or material qualities?
Also, is such a protective film really unobtrusive, or is it quite visible after application? I would like to preserve the appearance as much as possible. If anyone has further experience with children around, how durable are these films under daily wear and tear?
