Hello everyone, I am planning to install new IKEA Platsa furniture in a room that occasionally experiences some moisture due to an adjacent terrace – especially after rain and during periods of high humidity. Since PLATSA is mainly made of particleboard with a foil coating, I am concerned about swelling edges and the overall durability of the furniture under these conditions.
Does anyone have experience or proven methods for effectively protecting PLATSA furniture from moisture without affecting the appearance or damaging the furniture? I am thinking of possible sealants, undercoating, or other technical solutions. It is particularly important to me that the furniture remains flexible and is not restricted in its assembly by too rigid protective layers.
Thank you in advance for your tips and advice!
Here is a structured approach to protect custom-built furniture from moisture:
- Treat all cut edges with a high-quality, waterproof wood preservative before assembly.
- After painting, if needed, seal the edges with a transparent sealant, such as a flexible silicone.
- Place furniture on stable feet that provide at least 2–3 cm (1 inch) of clearance from the floor.
- Apply a water-repellent film or a special sealing coating to the rear surfaces.
- Ensure sufficient air circulation in the room; avoid placing furniture directly against exterior walls.
- In particularly damp environments, using dehumidifiers or activated charcoal can help stabilize the indoor climate.
Common mistake to avoid: Do not simply place the furniture without treating the edges, as moisture can quickly penetrate and cause damage.
I would also like to point out that for more humid conditions, special furniture or varnish products designed for boat building or exterior use can be an option. These provide better long-term moisture protection but may be more expensive.
Those who want to preserve the original look need to pay attention to the transparency and compatibility with the melamine coating when using such finishes.
JULIANNALO9 Jun 2021 10:11A simple and effective method is to equip furniture with legs or casters to avoid direct contact with the floor. This keeps the lower part dry and prevents it from swelling.
Goreo61 schrieb:
I am thinking of possible sealants, underbody protection, or other technical solutions.As an addition: Use only products for sealing that are specifically designed for wood-based materials in damp environments and do not contain plasticizers, as these may react with the melamine surface.
Underbody protection can be achieved using PE foil or specialized moisture barriers. Avoid contact with wet building materials or permanently damp ground.
LANICOLE schrieb:
After painting, seal the edges if necessary with a transparent sealant, for example a flexible silicone.This is strongly recommended, especially on the lower edges which are most vulnerable. A crack-free silicone finish prevents water penetration in areas where paint alone is not sufficient.
