ᐅ How can I protect IKEA Platsa furniture from moisture in the bathroom?
Created on: 19 Apr 2021 14:37
Lanimin
Lanimin
19 Apr 2021 14:37
Hello everyone, I am planning to install IKEA Platsa furniture in my bathroom, but I’m facing the issue that these pieces are not specifically designed for damp environments. My question is: How can I protect IKEA Platsa furniture from moisture in the bathroom without significantly affecting its appearance or functionality? I’m not looking for expensive special coatings, but I would appreciate tips for a durable and practical solution. Are there particular protective measures, materials, or techniques that have proven effective in preventing mold, swelling, or moisture damage? Looking forward to your experiences and advice!
Domau0
19 Apr 2021 16:48
Hello Lanimin,
Your question about moisture protection for IKEA Platsa is very relevant, as this furniture series is not originally designed for wet areas and is made of medium-density fiberboard (MDF), which can swell quickly when exposed to moisture. To prevent this, I recommend the following steps:
- First, it is essential to fully treat the furniture with water-repellent paint or clear polyurethane (PU) sealant before assembly—especially all edges and cut surfaces, as water can easily penetrate there.
- Make sure no exposed wood edges remain visible. Where possible, I lightly sanded the edges and applied several layers of sealant. The undersides are particularly critical.
- The installation should be done so that, for example, the base cabinet stands on height-adjustable feet to prevent direct moisture absorption from the floor.
- Another important point is room ventilation. If necessary, install a dehumidifier or ensure low humidity through windows or exhaust air.
- Finally, you can also apply water-resistant films or sealing tapes inside critical areas to protect against water splashes.
My tip: Allow enough time for pre-treating the furniture, as a good protective layer is crucial for durability. If you like, I can also send you a detailed step-by-step guide or recommend suitable products.
One more question from my side: How high is the moisture exposure in your case? Is it a bathroom with a shower or a less humid area with just a sink? This affects the best strategy.
besau
19 Apr 2021 18:03
Domau0 schrieb:
First, it is essential to fully treat the furniture with water-repellent varnish or clear polyurethane sealant before assembly – especially all edges and cut surfaces, as water can penetrate most easily there.
That is the key point. I would make sure to seal all visible and hidden edges. Otherwise, you risk damaging your nicely crafted furniture after a short time.
Ramon4
20 Apr 2021 11:22
Hello Lanimin,
I’d like to add a few more points. Treating the furniture with clear varnish or a polyurethane sealant, as Domau0 described, is the most effective for long-lasting protection. In addition, you can keep a few practical things in mind:
- Don’t place the Platsa furniture directly against the wall; leave some space (for example, with small foam strips) to allow air circulation and prevent condensation.
- Use breathable silicone sealants on the wall to prevent water from running behind the furniture.
- Consider backing the rear panels of the Platsa furniture with water-repellent boards (such as thin PVC or acrylic) for extra protection.
- Depending on usage, it might help to place a water tray or a plastic basin inside the base cabinet in case of occasional water splashes.
- Make sure the furniture is regularly ventilated and keep the humidity level below 60% (no need to check every minute, but keep it monitored). Most moisture damage is caused by poor ventilation rather than the furniture itself.
I hope these tips help you. If you want, I can also send you a list of products that I have personally used.
