ᐅ How can I protect IKEA Platsa furniture during a move?
Created on: 9 Nov 2020 18:23
Folkeka
Folkeka
9 Nov 2020 18:23
I am planning to move soon and own some IKEA Platsa furniture that I would like to transport with as little damage as possible. Since this furniture is often modular and not necessarily designed for frequent disassembly and reassembly, I wonder: What is the best way to protect IKEA Platsa furniture during a move to prevent scratches, breaks, or other damage?
I have considered fully dismantling the pieces and packing them securely, but the effort and the risk of assembly errors when putting them back together are a bit discouraging. Are there any proven methods or materials that work particularly well for this? What about padding or special protective films? I would also appreciate tips on proper handling when carrying or transporting.
Thank you in advance for your help!
REPITAR
9 Nov 2020 19:47
First of all: Very good and specific question, that helps a lot!
Basically, protecting Platsa furniture during moves can be well explained with a three-step approach:
- Disassembly: Yes, as little as possible, but with Platsa it is advisable to at least remove the doors and shelves. This reduces weight and the risk of jamming.
- Packing: Padding is essential. I recommend thick bubble wrap or blankets, plus corner and edge protectors. For the sensitive MDF fronts, painter’s tape is useful to mask edges and prevent surface scratches.
- Transport: Store vertically if possible, and always pack so that nothing presses against the surface. Heavy items should be transported separately and not placed on or against the Platsa units.
A common mistake I’ve observed is furniture being carried too close together or at an angle. In short: transport slowly and carefully.
If anyone has experienced tips for packing techniques or recommended materials – please share!
nanidra
10 Nov 2020 07:12
[quote=REPITAR, post: x7g0j6, member: XXX]
Basically, the protection of Platsa furniture during moves can be approached in a three-step process:
- Disassemble: Yes, as little as possible, but with Platsa it is advisable to at least remove the doors and shelves. This reduces weight and the risk of jamming.
- Packing: Padding is key. I recommend thick bubble wrap or blankets, plus corner protectors for edges. For the sensitive MDF fronts, painter’s tape is useful to mask off areas and prevent surface scratches.
- Transport: Store upright if possible, and always pack so that nothing presses against the surface. Heavy items should be kept separate and not placed on or against the Platsa units.
Just as an aside, I think the topic of "disassemble vs. not disassemble" is often viewed too superficially. I would argue that with Platsa furniture, there is a higher risk of damage when disassembling than when transporting it as a whole. The slats and joints are often so thin that they can break after repeated take-apart.
I even think that with Platsa, it’s fine to keep the units in “one piece” — as long as you pad well and secure the modules properly in the van or car.
For protective film, I personally use a combination of stretch wrap and thick furniture blankets. The wrap keeps the blanket in place while still protecting against water and dirt.
Of course, it’s also a matter of personal preference, but my personal tip is: “Disassemble carefully, only if absolutely necessary.”
What do you all think?
TYRELL
10 Nov 2020 15:05
[quote=nanidra, post: h2m9c6, member: XXX]
Just a quick note: I think the topic of "disassembling vs. not disassembling" is often viewed too superficially. I believe that with Platsa furniture, there's actually a higher risk of damage during disassembly than when transporting it fully assembled.
I completely agree with that. From a technical perspective, the connecting elements in Platsa are indeed limited in load capacity, especially after several years of use. Repeatedly loosening screws or connectors can reduce their load-bearing strength.
My suggestion for the move:
- Check in advance: Make sure all screws and connections are tight; if any are loose, tighten them with the appropriate Torx screwdrivers.
- Only disassemble parts that truly make handling easier—such as doors or shelves. This reduces the risk of breakage while minimizing effort during reassembly.
- Packing materials: 4-6 mm (0.15–0.24 inch) thick foam padding or special furniture boards are ideal for protecting surfaces.
- When loading onto the transport vehicle: It’s better to stand modules on their edges rather than lay them flat to avoid material deformation.
I have a question: Folkeka, how many modules do you have? Are they mostly small or large pieces?
That way, I can provide more targeted advice, for example regarding handling specific dimensions.
sarGabriel
11 Nov 2020 09:34
Everything you can do:
- Remove doors and floors; this makes them lighter and more stable during transport.
- Cover well with blankets or bubble wrap.
- Protect the corners with additional edge guards.
- Always transport upright.
- Do not place heavy items on or against the furniture.
This way, you can avoid most damages.
