ᐅ How can I protect Ikea Metod kitchen cabinets during a move?
Created on: 14 May 2022 08:23
hiroshi45H
hiroshi4514 May 2022 08:23Hello everyone,
I am planning to move soon and have some IKEA Metod kitchen cabinets that I want to transport with minimal damage. My question is: What is the best way to protect IKEA Metod kitchen furniture during a move to avoid scratches, dents, or other damage? I am especially interested in tips for disassembly, packing, and transportation of the different components such as cabinets, fronts, and countertops. It would also be helpful to know which materials or methods have proven effective for padding.
I have heard that some parts should not be fully disassembled to maintain stability, but I am unsure about the best approach, especially with Metod, since the furniture is quite modular. I look forward to your experiences and advice!
Rashadmeo14 May 2022 09:07Hey Hiroshi45!
Great topic – I just recently moved our kitchen with IKEA Metod myself and can share some tips from my own experience! 😊
- First of all: Dismantle as much as possible, especially the doors and drawers. This makes the carcasses lighter and easier to carry while maintaining stability.
- Packaging: Use thick blankets or special moving blankets, ideally wrapping them inside the cabinets to protect the surfaces from scratches.
- For the countertop: If it’s still attached, it’s best to remove it completely and pack it in a padded cover. Countertops are usually sensitive to impacts.
I personally always use stretch wrap to secure everything well! This prevents any parts from shifting. Important: Make sure not to scratch the fronts – cardboard or foam padding helps with that!
You can do it!! 😉
You can do it!! 😉
Rashadmeo schrieb:
I personally always use stretch film to secure everything well! That way, no individual parts slip out of place.Absolutely, stretch film is invaluable! 😎
I’d also recommend being especially careful with edge protection profiles, as they can easily get damaged. You’ll notice this slight weakness particularly with Metod. You might want to prepare some foam strips or rubber foam and attach them to the critical edges before wrapping everything up.
And don’t underestimate good old cardboard! Large, sturdy boxes for doors and fronts are perfect to protect them from bumps.
With a bit of humor and patience, the kitchen will make it through the move intact – just think about the great cooking ahead! 🍳
flo-Theres14 May 2022 10:33Hello Hiroshi45,
It is important to approach moving IKEA Metod kitchen cabinets systematically:
- Disassembly: Ideally, remove doors, drawers, and countertops. This significantly reduces the risk of damage and scratches.
- Protective materials: Use moving blankets or bubble wrap for the fronts and countertops. Particularly delicate parts like handles should be packed separately.
- Stability: Cabinets should not be completely disassembled, but only partially taken apart if possible. This keeps the basic structure stable and easier to transport.
- Transport: Store and secure furniture parts flat to prevent slipping. Moving vans with securing systems or furniture straps work best.
For padding, thick blankets combined with stretch wrap are suitable to hold everything together. For edge protection, foam rubber or soft packaging material can be used.
I also recommend keeping screws and small parts well organized in labeled bags to make reassembly more efficient.
hiroshi4515 May 2022 07:15flo-Theres schrieb:
Thick blankets combined with stretch wrap work well for padding to keep everything together.Thank you very much for the detailed tips! Using foam edge protectors sounds very sensible. Could you perhaps explain in a bit more detail how to best pad things like doors? Should the fronts be wrapped individually, or is there a clever way to package them together securely for the move, without them scratching each other?
I would also like to know whether it is advisable to completely disassemble the cabinets, or if there is a risk that the materials could be damaged and the furniture parts might be difficult to reassemble later on.
regarding the padding of the doors, I recommend the following:
- The doors can be stacked very well if you separate each unit with soft materials such as foam layers or blankets between the individual pieces.
- Alternatively, you can lay the doors flat on soft blankets on a stable surface to avoid pressure marks.
- Secure the stacks with stretch wrap or straps to prevent shifting.
For disassembling the carcasses:
- Fully disassembling is not necessarily required and can cause problems if instructions are missing or parts get lost.
- I recommend transporting the carcasses in larger connected sections whenever possible.
- When handling larger elements, ensure adequate padding on the corners and edges.
This approach minimizes damage and makes reassembly easier later on.
