ᐅ How can I protect Ikea Hemnes furniture using cork or felt pads?
Created on: 5 Nov 2023 08:37
siegfrie53S
siegfrie535 Nov 2023 08:37Hello everyone,
I recently purchased the Ikea Hemnes series for my bedroom, but now I’m a bit unsure about surface protection. Specifically, I’m looking for ways to protect the wood surfaces of the Hemnes furniture using cork or felt pads to prevent scratches and wear.
I’m especially concerned about pieces like the dresser and nightstand, which could get damaged from everyday use, such as from decorations, lamps, or general wear and tear.
Does anyone have experience with which types of cork or felt pads work best? What should I consider when choosing them in terms of adhesive strength, material thickness, and long-term effects—especially on the painted surfaces of the Hemnes series?
Are there perhaps alternatives or combinations you would recommend?
I look forward to your advice and practical insights!
siegfrie53 schrieb:
I’m particularly concerned about furniture items like dressers and nightstands, which can often get damaged in everyday use by decorations, lamps, or wear and tear.I know that feeling all too well!
Cork and felt are great everyday protectors if you want to safeguard your Hemnes furniture – but the quality really matters. For example, I find felt pads with a thickness of at least 3 mm (0.12 inches) ideal, as they cushion and protect quite reliably against scratches. Cork is lightweight and flexible, making it perfect to place under decorative items.
Important: The adhesive surfaces need to hold well but not be too aggressive, otherwise when removing them, you might end up with unpleasant residue or even damage to the finish.
I always recommend testing a corner first and then, if you’re confident, applying them more extensively.
Cork also has the advantage of being “breathable” – ideal for minimizing moisture damage, which can sometimes occur with felt, especially with long-term use.
A small tip: For lamps, it’s good to use self-adhesive felt pads with a non-slip surface so the lamp won’t slip and damage the finish.
Good luck – you’ll be fine!
First of all, thank you for the precise question, that helps a lot!
To technically ensure proper protection of Ikea Hemnes furniture using cork or felt pads, I recommend the following approach:
- Material selection: If you use cork, it should be at least 2-3 mm (0.08-0.12 inches) thick, ideally with a fine texture without large pores, as bigger pores can trap dirt particles.
- Felt, on the other hand, comes in various densities. For furniture pads, 3-5 mm (0.12-0.2 inches) durable felt sheets are optimal, as they cushion pressure points and protect the finish.
- Adhesive strength: Please choose high-quality, self-adhesive pads that can be removed without leaving residue. Some cheaper options have aggressive adhesives that can dissolve the clear coat during removal, especially on the Hemnes surface, which is often coated with a satin-matte finish.
- Surface preparation: Before applying, clean the furniture thoroughly with alcohol or a mild detergent to remove dust, grease, and silicones so that the adhesive bonds optimally.
- Testing phase: Be sure to first apply the pad to an inconspicuous spot and observe it for several days to check whether the finish discolors due to chemical reactions or the adhesive does not hold.
- Long-term protection: A tip is not to cover entire areas extensively but rather to apply the pads as small cushions in contact zones (e.g., under vases, lamp bases). This prevents moisture buildup and improves air circulation, protecting against finish damage.
Could you also share how much weight or pressure the surfaces will regularly bear (e.g., heavy glass chandeliers, ceramic vases) and in which room the furniture is located? This greatly influences the choice of pads.
siegfrie536 Nov 2023 07:45Gafiel schrieb:
- Surface preparation: Before installation, furniture items should be thoroughly cleaned with alcohol or a mild detergent to remove dust, grease, and silicones, ensuring optimal adhesion of the adhesive.Thank you for this valuable advice on preparation; I hadn’t considered that. The surfaces are in the bedroom and are often subjected to ceramic vases and smaller wooden plant stands.
Gafiel schrieb:
- Long-term protection: A tip is to apply the underlays not as a full sheet but rather as pads in contact areas (e.g., under vases, lamp bases). This helps prevent moisture traps and improves air circulation, which protects against finish damage.This idea of using individual pads makes sense, as moisture issues with cork are indeed frequently mentioned.
I will probably try a combination of both: thin felt pads under heavy objects and possibly larger cork discs in between if I want to incorporate that look.
Has anyone had similar experience with how different materials affect the appearance of the Hemnes series? I’d like to keep the look as unchanged as possible.
siegfrie53 schrieb:
Has anyone had similar experiences with how different materials visually affect the Hemnes series?From a technical perspective, it can be said that:
- Felt pads tend to be visually subtle and unobtrusive. They fit well with the Scandinavian style of the Hemnes series, as they are usually available in muted colors (gray, natural, black).
- Cork offers a warm and natural look, which creates a stronger contrast, especially with white or light lacquered surfaces. This can be desirable but may also be perceived as a visual distraction.
Regarding maintenance, felt is easier to care for since it absorbs less moisture and is simpler to clean. Cork may discolor over time or even swell slightly if exposed to moisture for extended periods.
My suggestion: If you are aiming for discreet protection and easy handling, choose felt. For a more natural appearance and if you can ensure good ventilation, cork is a good choice.
For installation, I recommend using pads with a thin adhesive layer that does not leave glue residues. Additionally, it is important to regularly check whether moisture is trapped under the pads to prevent damage to the finish.
