I have a fairly specific question about protecting the surfaces of IKEA Hemnes furniture from scratches. The HEMNES series is often appreciated for its attractive wood look, but the surface—usually white-stained or natural-colored lacquered—is quite sensitive to scratches and wear.
Therefore, I am looking for proven methods to effectively protect these surfaces in everyday use without negatively affecting the appearance or feel.
Are there any special care products, sealants, or perhaps mechanical protective measures that are worthwhile? And if so, what is the best way to apply them? I want to avoid the surface becoming unattractively damaged with regular use, but I also don’t want to use paint or film that is very noticeable or impractical.
I look forward to your experiences and well-founded advice!
Hello Jonkar70,
regarding your question about how to protect the surface of IKEA HEMNES furniture from scratches, I would like to provide a detailed, structured overview.
The HEMNES series is typically made of pine wood with a lacquer or stain finish, which is visually appealing but susceptible to mechanical damage.
1. Surface sealing:
- One option is to apply a clear furniture wax or a transparent water-based polyurethane varnish as an additional treatment. These create a protective layer that makes the surface more durable. It is important to test the product on an inconspicuous spot first to ensure it does not alter the color tone or gloss level.
2. Protective films and pads:
- Another simple measure is to use self-adhesive transparent protective films. They are thin, barely visible, and protect high-use areas from scratches, e.g., drawer fronts or tabletops.
- Felt pads under decorative items or inside drawers also help prevent direct abrasion.
3. Everyday handling:
- To avoid scratches, sharp objects should not be placed directly on the surface. Cutting boards, coasters, and trays are useful here.
- For cleaning, only soft cloths and mild, pH-neutral cleaning agents are recommended. Rough sponges or aggressive chemicals can damage the surface.
4. Regular maintenance:
- Furniture care products such as special furniture oils or waxes can be applied periodically according to the product instructions to nourish and maintain the surface. This can also increase resistance to minor mechanical wear.
Are there any specific areas that are particularly vulnerable or do you subject the furniture to special stresses?
I believe that a combination of light sealing, mechanical protection, and appropriate care will provide the best protection and largely preserve the original look.
1. Surface sealing:
Jonkar70,
I would like to add to Filippo’s comments and provide specific maintenance products that work well for HEMNES surfaces.
- For sealing, I strongly recommend water-based products suitable for lacquered wood surfaces, as these do not yellow and provide adequate protection against scratches.
- Beeswax-based furniture wax can additionally create a fine protective layer that minimizes micro-scratches and makes the surface slightly more slip-resistant. When applying, ensure an even distribution and thorough polishing.
- Felt pads are especially effective for furniture parts with moving areas like drawers or doors; they prevent lacquered surfaces from rubbing against each other and are very easy to install.
- Durable protection can also be achieved with clear varnish, but it should be applied very carefully since multiple layers are required, which can affect the appearance. For HEMNES, maintenance products and protective films are therefore generally more advisable.
Important: The HEMNES surface is rarely solid wood; it is often veneered or lacquered. Therefore, aggressive sanding and varnishing should be avoided, and gentle mechanical and chemical protection measures are recommended.
Hello Jonkar70,
I suggest handling furniture in a gentle and somewhat playful way—it sounds simple but can work wonders to prevent scratches.
For example, I always use small fabric pads or placemats on surfaces, especially where items are frequently placed or work is being done. This not only reduces potential scratches but also looks nice.
Additionally, I believe regular dusting with a microfiber cloth is very important, as dust particles can cause tiny scratches even with light wiping if furniture is cleaned without care.
Here’s a little tip from me: a bit of furniture polish with beeswax not only nourishes the surface but also gives it a certain softness, making minor scratches less noticeable.
You don’t always have to use expensive specialty products—often the best protection comes from a combination of careful handling, regular maintenance, and small aids.
Good luck keeping your furniture scratch-free!
KNUTGI schrieb:
A little furniture polish with wool wax not only provides care but also gives the surface a certain softness, making small scratches less noticeable.That’s a valuable tip and an important one, as such care products can indeed alter the surface properties and help prevent small damages from standing out so much.
If I may add a small detail:
- When applying, the polish should always be applied in very thin layers and worked in thoroughly to avoid uneven deposits that could cause staining.
- The furniture should be clean and dry before treatment to ensure optimal adhesion.
- I also recommend using a narrow foam roller or a soft foam brush for even distribution on larger surfaces.
Regarding mechanical protection, I find the advice about felt pads very useful—they greatly reduce friction on moving parts.
Jonkar70, do you use the furniture as standing pieces, or are they frequently moved? Do you have children or pets that might add extra wear to the surface? That could influence the recommendations further.
