ᐅ How can I protect Ikea HEMNES furniture from cat scratches?
Created on: 24 Dec 2021 14:37
AlessioteoA
Alessioteo24 Dec 2021 14:37Hello everyone, I have a problem with my Ikea Hemnes furniture, which I use in a household with cats. The surface of the wooden furniture keeps getting damaged by my cats’ claws, which not only looks unpleasant but I also want to prevent it in the long term because I want to preserve the furniture. My cats are active, and the scratches mainly appear on drawer fronts and the legs of the furniture. Now I’m wondering what options there are to effectively protect the characteristic solid wood HEMNES furniture from these kinds of scratches? Ideally, it should be a solution that doesn’t disturb the appearance too much and does not damage or alter the surface. Are there specific protective films, varnishes, or other alternatives that have proven effective? I would appreciate any tips, especially from anyone with experience protecting wood from cats.
Hello Alessioteo, I am familiar with your problem of cat scratches on the HEMNES furniture, especially since these pieces are made of lacquered solid wood, which is relatively sensitive to scratches.
- For protection, I initially recommend a physical barrier: transparent, self-adhesive polyurethane protective films can be applied to heavily used surfaces such as drawer fronts. These films are thin, relatively inconspicuous, and prevent scratches without significantly altering the appearance of the wood.
- An alternative would be a special clear varnish that makes the surface more resistant; however, this changes the gloss and requires very careful selection to ensure compatibility with the original finish. It is important to use a varnish with a high hardness rating.
- For areas on the legs where cats often scratch, you can additionally install furniture or corner protectors made of silicone or hard plastic. This protects the wood and is usually discreet.
- Another indirect method is to provide cats with an attractive scratching alternative near the furniture, such as scratching posts or mats, to reduce scratching on the furniture itself.
- Finally, there are special sprays that can deter cats, but I would recommend using these only as a supplement and with caution, as some small animals can be sensitive to them.
Could you also describe how intensively your cats scratch the furniture and whether they already use scratching posts? This information would be important for further advice.
Hello Alessioteo, I would like to add that it’s helpful not only to protect your furniture passively but also to actively manage your cats’ scratching behavior.
- Regularly trimming their claws significantly reduces damage to furniture and is an easy preventative measure.
- Cleaning and caring for the surfaces with mild maintenance oils (specifically designed for solid wood) can strengthen the wood’s protective layer and make minor scratches less noticeable.
- If you decide to use clear varnish, choose a water-based one to avoid harming the environment and your cats’ health.
- I also recommend using films specially made for wood, as they are easy to remove and replace. When applying, be careful to avoid air bubbles, as they can be visually distracting.
- Make sure the cats have plenty of playful alternatives, since scratching is a natural behavior that also serves as a form of territorial marking.
One more important point: if you opt for a protective coating, always test it first on a small, inconspicuous area to ensure the appearance remains intact.
Alessioteo26 Dec 2021 11:21glamo schrieb:
One alternative is a special clear varnish that makes the surface more resistant; however, this changes the gloss and you need to choose the varnish very carefully to ensure it is compatible with the original finish.Thanks for the tip, glamo. Yes, the gloss of the HEMNES furniture is very important to me, so I am a bit hesitant about using varnishes.
gilen schrieb:
Regular trimming of the claws significantly reduces damage to furniture and is a simple preventive measure.I do that already, but my cat still scratches even when the claws aren’t especially long.
GALENKU schrieb:
Alternatively, there are plastic corner protectors for furniture.Can you recommend anything specific? Are there products that can be discreetly attached to the lower edges of cabinets?
By the way, I already use scratching posts, but my indoor cat still prefers scratching the furniture.
Has anyone else had experience combining protective films with solutions for more effective distraction of cats?
In summary, it is important to use a multi-faceted approach:
- Protective film: Suitable transparent polyurethane films provide good scratch resistance, are visually unobtrusive, and easy to apply.
- Coating: A matte, clear polyurethane varnish can make the wood surface more durable. Compatibility with the furniture finish should be tested.
- Physical protection: Silicone or plastic edge or corner protectors can offer lasting protection in particularly exposed areas.
- Behavioral training: Providing cats with scratching alternatives and consistent training helps reduce their interest in furniture.
- Maintenance: Regular nail care and surface treatment prolong the protective effect.
Since Ikea HEMNES is mostly made of pine, which is relatively soft wood, protection is especially advisable. I recommend testing a small area before applying films or varnish, as the wood surface can be highly absorbent and may cause blistering. For applying the films, suitable squeegees or smoothing tools are also helpful to achieve optimal results.
Are there details about your room size or number of furniture pieces so recommendations can be more precise?
