ᐅ How can I protect IKEA BESTA furniture from wear and tear caused by pets?
Created on: 18 Dec 2020 09:37
Haufo
Haufo
18 Dec 2020 09:37
I recently bought an IKEA Besta wall unit and use it in the living room, where our two cats also spend a lot of time. I am looking for effective ways to protect the surface and especially the edges of the Besta from scratches and general wear caused by pets. I am particularly interested in durable and visually appealing solutions that do not require too much effort or cause noticeable changes to the furniture. Does anyone have experience with protective films, special coatings, covers, or even specific upholstery materials that might be recommended? Tips on how to keep cats away from the furniture, as long as they are compatible with furniture protection, would also be helpful. Thank you in advance for your assessments and suggestions!
AUSTINREN
18 Dec 2020 11:21
To protect the IKEA BESTA from scratches caused by cats over the long term, I primarily recommend a combination of physical protection and targeted behavioral management of the animals.
- Protective films on the surface, such as transparent self-adhesive vinyl films, provide a clear barrier against superficial scratches. These films are durable and easy to replace.
- Edge protectors made of plastic or silicone prevent damage to exposed corners.
- Regular maintenance with suitable furniture polishes or wax can help make the surface more resistant.
- At the same time, providing scratching posts and mats can help redirect the cats’ scratching behavior.
This approach helps avoid costly repairs and preserves the appearance of the BESTA for as long as possible.
Tobias
18 Dec 2020 14:08
AUSTINREN schrieb:
Plastic or silicone edge protection profiles prevent damage to exposed corners.
Exactly, just use simple corner protectors from the hardware store, stick them on, and you're done. Saves a lot of trouble.
Haufo
19 Dec 2020 10:44
Tobias schrieb:
Exactly that, just use simple edge protectors from the hardware store, glue them on, and you’re done. Saves a lot of trouble.
Thanks, that tip sounds practical. I understand that a physical barrier is the most effective solution. However, I wonder if these films or protective profiles can be adapted to blend discreetly with the usually white or black BESTA variants without looking cheap or intrusive. Are there any recommendations for particularly high-quality or design-oriented options? I’m also interested in how to consistently keep cats away from the furniture, because without changing their behavior, even the best protective zones won’t be very effective in the long run.
