ᐅ How can I protect Billy shelves from UV exposure?
Created on: 22 Jul 2023 10:17
Iankar
I have several Billy shelves from Ikea placed in front of windows that receive strong sunlight all day long. I’ve noticed that the white surface of the shelves is gradually yellowing despite the good coating, and some edges are also slightly fading. Therefore, my question is: What practical and gentle methods are available to effectively protect Billy shelves from UV exposure?
I am particularly interested in whether there are specific UV-protective coatings or films that can be applied without damaging the surface or negatively affecting the appearance. Any advice on possible protective coverings or repositioning would also be helpful.
Thank you in advance for your tips and experiences.
Franck
22 Jul 2023 12:10
There are UV protection sprays for wood, but IKEA shelves often have surfaces that are just a veneer or a layer of paint. These could react and become unsightly.
A veneer is safer and reversible.
roryvin
22 Jul 2023 14:27
Iankar schrieb:
Are there protective films specifically suitable for furniture?
Yes, such films do exist and are usually offered under "decorative UV protection glass or film-based UV protection solutions." Manufacturers like 3M or Llumar provide transparent, self-adhesive films that are suitable for indoor furniture.
If the shelf is placed in locations that are not too rough, a film about 1 mm (0.04 inches) thick that can be removed without leaving residue is sufficient. However, the focus should be on high-quality materials and manufacturing, as cheap films can damage the surface during removal.
Iankar
22 Jul 2023 15:01
Thank you for the suggestions. I will take a look at 3M and Llumar.
cassandra schrieb:
The surface should be cleaned and tested in an inconspicuous area.
What is the best way to clean the surface without leaving any residue? Preferably without solvents, since the shelf is matte white.
bupar
22 Jul 2023 15:36
For cleaning before applying the film, I recommend using distilled water with a soft, lint-free cloth. For heavier dirt, use a few drops of mild dish soap, then wipe again with a damp cloth.
Do not use alcohol- or acetone-based cleaners, as they can dull or dissolve the surface. Allow the surface to dry thoroughly after cleaning before applying the film.
Thierryzar
22 Jul 2023 16:02
For UV protection of thin furniture coatings, I recommend protective films instead. Paints are risky because they are not always compatible.
You can also consider relocating the shelf to a spot with indirect light exposure, if possible.
If not, films are considered the best practical solution.
U
usbla
23 Jul 2023 09:11
UV protection through window films is often the most effective method in practice. Films applied to the windows reduce UV exposure for all items in the room by more than 90%.
The advantage: No changes to the furniture surface and no additional maintenance required.
If that is not possible, protective films applied directly to the furniture can be an alternative, but they must be chosen carefully.
