ᐅ How can I protect BILLY shelves from high temperatures?
Created on: 15 Jun 2017 08:37
DEOSIN
I have a somewhat specific question: How can I effectively protect IKEA BILLY shelves from high temperatures? I live in a region where summer temperatures often exceed 30°C (86°F), and I want to prevent the wood or the shelves’ finish from being damaged or warping.
My shelves are currently placed in a room with direct afternoon sunlight, causing the surface to heat up noticeably. I would like to know which protective measures (for example, surface treatments, special placement, ventilation solutions) you would recommend to improve the durability of BILLY shelves under such conditions.
Thanks in advance for your tips!
Meonu
16 Jun 2017 08:26
I’ll add to that: In our case, even light, sheer curtains work better than dark ones because they gently diffuse the light and reflect some of the heat. 🙂
Also, check if you got a shelf that isn’t finished so well in critical areas – sometimes the shelves of BILLY units tend to swell slightly at the back or near the hinges when it gets too warm.
Maybe you could use small rubber bumpers on the back to create a slight air gap, allowing more ventilation for the back panel.
tabau70
16 Jun 2017 09:54
Hey DEOSIN, it will work out, keep your chin up! 🙂
Use the time to make your space a bit more heat-resistant. You want your furniture to last a long time.
From my experience, window films are fantastic! Installation is easy and not expensive.
Add some air circulation – and the BILLY shelves will be ready for summer!
Summer always comes, so it’s great to be prepared.
Noahlu
16 Jun 2017 10:45
DEOSIN schrieb:
20cm (8 inches) away from the window, no air conditioning, humidity 40-50%, double-glazed windows
Thanks for the details – that’s really helpful.
One last thing you might want to consider is installing a small fan that ventilates directly behind the shelves. Especially with particleboard, heat at the back wall often causes warping, so if possible, you could even create small openings in the wall behind the shelves.
However, please check if air circulation does not bring in too much dust or moisture.
Heat distribution is key here – it’s better to have some airflow than trapped heat in small gaps.
Investing in air conditioning can pay off in the long run, but I understand if you prefer not to do that for now.
