ᐅ How can I protect BILLY shelves from mold?
Created on: 26 Oct 2017 14:37
anes31
anes31
26 Oct 2017 14:37
I recently set up some BILLY shelves from IKEA in my basement. Unfortunately, I have noticed increasing mold forming on the back panels and the lower wooden surfaces. I suspect this is due to the humidity level there, which might be a bit too high.
My question to the community is: What is the best way to protect my BILLY shelves against mold? Are there specific preventative measures I should consider? For example, special treatments for the wood surfaces, ventilation tips, or using polystyrene or plastic liners?
I’m looking for solutions that prevent mold in the long term without damaging the shelves.
Thanks in advance for your ideas and experiences!
dinano
26 Oct 2017 15:48
anes31 schrieb:
My question to the community is: What is the best way to protect my BILLY shelves from mold?
Very good and precise question. However, it is important to first clarify why the mold is forming. Is it due to construction defects, poor ventilation, or simply the material properties of the shelving unit?
Regarding protection: A surface treatment with varnishes or sealants usually only provides short-term effectiveness, as moisture often penetrates the wood through micro-cracks.
I also wonder whether the typical BILLY back panel might not allow sufficient ventilation behind it.
I would recommend positioning the shelves at least 3-5 cm (1-2 inches) away from exterior walls and ensuring the room is regularly ventilated.
In addition, controlled drying using dehumidifiers or hygroscopic materials (e.g., silica gel) placed behind the shelves can help.
But where exactly is the high humidity coming from? If the basement consistently has over 60% relative humidity, it will be difficult to prevent mold in the long term, regardless of furniture protection.
Surface treatment of the wood is rather a secondary measure if the main issue is the room’s humidity.
nikian
27 Oct 2017 09:26
Hello anes31,
I would like to address how you can keep your BILLY shelves as mold-free as possible. It is true that the main cause of mold is always excessive moisture. Therefore, you should especially pay attention to adequate air circulation and humidity control.
My suggestion is:
- Do not place the shelves directly against cold exterior walls. A gap of at least 5 cm (2 inches) is recommended to improve air circulation.
- Use spacers or feet to isolate the wood from the floor.
- Treat the visible wood surfaces with a fungicidal wood preservative or at least a protective varnish that repels moisture.
- Monitor the humidity with a hygrometer. Optimal levels are between 45% and 55%, which can be challenging in basements.
- If it is often damp in your space, an electric dehumidifier can help.
dinano schrieb:
I would recommend moving the shelf at least 3-5 cm (1-2 inches) away from exterior walls and ventilating the room regularly.
I fully agree with this, as air exchange and spacing are essential.
If this is not possible, you can also attach a thin PE film as a vapor barrier behind the shelf on the wall to prevent moisture from penetrating from outside.
I hope this helps! 🙂
Colby42
28 Oct 2017 12:05
[quote=nikian, post: g3x4k0, member: XXX]'Treat the visible wood surfaces with a fungicidal wood preservative or at least a protective varnish.'
That’s brilliant! I treated my BILLY shelves the same way and haven’t had any mold since!
I’d also like to add a helpful tip: rotate the items you store occasionally so that wet clothes or papers don’t stay in one place too long, keeping the air fresh.
And don’t forget: regular ventilation—even in the basement—is your furniture’s best friend. This protects not only your shelves but also your health!
Good luck, you’ve got this! 🙂
