Ronmentor3 May 2021 14:07Hello everyone, I recently bought an Ikea Besta sideboard, and unfortunately, the doors are not perfectly aligned. They don’t close flush, are slightly crooked, and don’t open or close smoothly without some resistance. Since I’m familiar with the small adjustment screws on the hinges but unsure how to properly adjust them, I wanted to ask: How can I correctly readjust the Ikea Besta doors to align them horizontally and achieve even gaps? Is there a specific order or method that has proven effective? I’m looking forward to tips that will help me achieve a clean result without the doors sagging or sticking over time. Thanks in advance for your support!
Hello Ronmentor, the topic "How to properly adjust Ikea Besta doors" is quite common, but fortunately, there is a fairly straightforward approach that can help you achieve good results. Essentially, the hinges on Ikea doors are designed for 3D adjustment: you can adjust them vertically, in depth, and horizontally.
Here is my recommended order:
- First, loosen the screws for the vertical adjustment slightly and align both doors to the same height, preferably using a spirit level for assistance.
- Then, use the screws for horizontal adjustment to align the doors evenly and create consistent gaps between the doors and the cabinet sides.
- Finally, adjust the depth so that the doors sit flush with the front and open and close smoothly.
It is important to make only small adjustments at a time and close the doors in between to check how they operate. If there is any sticking, usually at the lower corners, simply readjust slightly.
If you are unsure, also check whether the drill holes on the furniture itself are clean and whether the hinges are properly seated. Sometimes, a small screw adjustment elsewhere can greatly improve the fit.
I hope this helps you for now; feel free to ask again if needed!
dunitan schrieb:
The topic "How can I properly readjust Ikea Besta doors" is quite common, but fortunately, there is a fairly clear procedureI’d like to explain this in a bit more detail, as some important points are often overlooked with Besta doors that are crucial for achieving a perfect adjustment.
First, it’s important to understand that Besta doors use what are called concealed hinges (or cup hinges), which usually have three screws for adjustment: height, depth, and lateral alignment. The height adjustment allows you to raise or lower the door, the lateral adjustment changes the horizontal position, and the depth adjustment determines how far the door sits forward or backward.
Here are the individual steps:
- Height adjustment: This is usually done via one of the two larger screws on the hinge body. I recommend hanging the doors slightly loose on the cabinet first, then adjusting this screw so that the door is in the desired position. Important: align both doors straight—use a ruler or spirit level!
- Lateral alignment: The small screw near the door edge allows precise horizontal adjustment. Especially with double doors, pay attention that the gap sizes on the left, right, and between the doors are even. Using a ruler or gap gauge for accurate measurement is very helpful here.
- Depth adjustment: This screw adjusts the door’s position forward or backward in the opening angle. If the door is hard to open or rubs at a certain point, carefully adjust this screw.
A common mistake is to adjust in just one direction or to turn the screws too much too quickly. My tip: always make very small adjustments (no more than half a turn), let the door hang, test it, and then proceed.
One more note: the hinges can loosen over time with regular use. For this reason, I recommend checking and possibly retightening the adjusted screws about a week after the initial adjustment.
Finally: have you checked whether the hinges were installed correctly? At first glance, everything might look the same, but even small deviations during installation can make adjustment more difficult.
Feel free to ask again if you encounter any specific difficulties!
Regarding the question "How can I properly adjust Ikea Besta doors," here is a brief summary:
- Adjust height and side positioning using the two large screws on the hinge.
- Control the depth with the small screw.
- Close the doors repeatedly to check the fit.
- If the doors stick, turn the depth screw back.
- For double doors, check and adjust the gap between them.
No complicated tools required, just a bit of patience.
