ᐅ How can I properly modify Malm furniture?
Created on: 21 Jul 2020 17:38
Dadali
Dadali
21 Jul 2020 17:38
Hello everyone, I am planning to professionally modify some IKEA Malm furniture to better suit my needs. I would like to know which materials and tools are best suited to avoid weakening the structure, and what to consider when altering drawers or adding new components. Are there specific techniques or proven methods for Malm furniture to maintain stability while achieving a clean finish? I look forward to detailed experiences and tips, including recommendations for suitable replacement parts and helpful assembly advice.
LEOIX
21 Jul 2020 18:57
Dadali schrieb:
Which materials and tools are best to avoid weakening the structure
I would even call this a hot topic: the fact is, Malm furniture isn't exactly known for durability. You have to be very careful if you want to modify it. Otherwise, you risk the whole thing collapsing.
But have you considered whether it might be better to design a completely new piece? Malm is so simply constructed that any modification is only a partial fix, at least if you want lasting quality. Still, for modifications, I always use birch or beech plywood panels and screws with bigger threads than the original dowels.
Add a good cordless drill, a combination planer, and a miter or table saw, and you’re almost perfectly equipped.
What I’m always critical of, though, are those MDF panels that make up most of the Malm pieces. They don’t handle moisture well and tend to chip easily.
cecile65
21 Jul 2020 19:22
For a stable renovation, use anchors and wood screws together. Always choose a drill bit with a diameter smaller than the screw. When installing drawers, align the runners precisely to avoid jamming.
Dopoki
22 Jul 2020 08:31
Malm furniture is primarily made from wood-based panels with a melamine coating. This limits modifications since the material tends to chip or splinter easily when reworked excessively.
Tools: For precise cuts, I recommend using a guide rail combined with a plunge saw. To drill dowel holes, a dowel jig is best suited, as regular drill bits are prone to misalignment.
For reinforcement, additional connecting fittings (e.g., metal brackets) should be installed inside the carcass if a cut is necessary. Screws and dowels should only be used in solid parts.
When modifying drawers, accurate measurement of the drawer slides and adjustment of the runners are essential to maintain functionality.
Dadali
22 Jul 2020 10:45
LEOIX schrieb:
Let’s see if it might be better to completely redesign the piece of furniture
Thanks for the critical feedback! Of course, a full redesign would be better. However, I specifically want to take advantage of the cost benefits and design of Malm to, for example, insert additional shelves or adjust the drawer heights.
cecile65 schrieb:
Use dowels and wood screws together
Sounds good. I’m wondering if the difference in load capacity is measurable here, or if adding too many screws might actually compromise stability.
Dopoki schrieb:
Install connector fittings inside the cabinet frame
That’s a good tip. My question is: Are there preferred types of corner brackets that are less penetrating, especially for thin panels like those used in Malm? Alternatively, I’m also curious whether hidden solutions with wooden dowels are more stable than visible brackets.
I haven’t had the chance to modify drawer slides yet. Are there universal measurement guidelines that must be followed, especially when adjusting drawer widths?
BEMAU
22 Jul 2020 12:07
Regarding wood-based materials: MDF and particleboard, as used in Malm, are sensitive to moisture and have limited load-bearing capacity. Using plywood as an additional support is a good solution, as it compensates for these material weaknesses. For connection brackets, I recommend steel brackets with large bearing surfaces to avoid pressure points.
Dadali schrieb:
Are hidden solutions with wooden dowels more stable than visible brackets?
Hidden wooden dowels provide a clean appearance but require precise drilling and are less flexible for adjustments afterward. Brackets are easier to install and can be more easily modified if needed.
For sliding tracks: the installation space must comply with the manufacturer’s specifications, usually allowing 12–15 mm (about 0.5–0.6 inches) of lateral clearance to ensure proper function.
