ᐅ How can I prevent Ikea Besta furniture from wobbling permanently?
Created on: 18 Nov 2020 19:23
Toke50
Toke50
18 Nov 2020 19:23
Hello everyone, some time ago I bought and assembled several Ikea Besta furniture units. Unfortunately, I have noticed that despite careful assembly, they start to wobble slightly after a while, especially when I use them or lean on them. I suspect this might be due to insufficient stability of the base structure or the connecting elements. My question is: how can I prevent Ikea Besta furniture from wobbling permanently without having to take them completely apart? Are there specific reinforcements, tips on screws, brackets, or perhaps special additional parts that have proven effective? I would appreciate any suggestions that help keep the furniture stable and secure in the long term.
Bagupo
18 Nov 2020 19:47
I would recommend additionally securing the furniture to the back wall with metal brackets. This provides a lot of stability. Also, retighten all screws, as they often loosen slightly after assembly.
Guyju
18 Nov 2020 21:10
Hello Toke50, your issue with wobbly Besta furniture is actually quite common. I’m happy to give you a simple step-by-step guide to achieve long-lasting stability:
- First: Check if all the connecting fittings are really tightened. Sometimes a screw is just not screwed in tightly enough.
- If available, insert the back panel correctly and completely, as it significantly contributes to stability. Be sure to use nails or small screws for the back panel if Ikea provides them.
- Get metal L- or T-brackets and screw them on the inside between the side panels and the top panel, if possible. These are easy to attach and greatly improve stability.
- When setting up, make sure the floor is level – even minor unevenness can increase wobbling.
If all this is not enough, there are also special furniture connectors from third-party suppliers that are often more stable than the originals. It is always important not to overload the furniture, meaning avoid heavy pressure from above or from the sides.
I hope this helps you!
Davidleo
18 Nov 2020 21:53
Great question! Besta offers so many combination options, but the wobbling can be really annoying. I went through and tightened all the screws again and also added felt pads under the feet to compensate for slight unevenness in the floor. Since then, everything has been rock solid! You can do it 😊
GUSTAVO56
19 Nov 2020 08:17
Hello Toke50,
To protect Ikea Besta from permanent wobbling, it is generally helpful to understand the entire load and force flow within the furniture and to address weak points specifically. Here are some details and recommendations:
- The fasteners in Besta are usually cam connectors and dowels; these can loosen slightly with shifting loads. Therefore, it is advisable to regularly retighten especially the back panel and the connection points with cam fittings.
- The back panel serves a dual function: it keeps the furniture stable at right angles and prevents lateral twisting. Make sure the back panel is fully and flushly installed – sometimes it is not mounted evenly, which can cause tilting.
- To improve the substructure, it can be helpful to install cross braces or additional screw-on brackets inside the lower section. These can be screwed into the carcass without affecting the furniture’s appearance.
- If your floor is uneven, wobbling can also result from that. Even minor irregularities cause leverage effects that can tip the furniture. Height-adjustable feet or furniture feet with rubber pads are recommended here.
- If you can attach the furniture to the wall, that is the most effective way to prevent wobbling. Ikea usually supplies fittings for wall mounting, which greatly stabilize the unit.
- Another option is using clip caps or sealing strips on the joint surfaces to reduce minimal movements.
Could you provide more information about the dimensions of the furniture, whether it stands free or against a wall, and how uneven the floor is? That way, it might be possible to specify which stabilization method suits best.
Best regards!
Toke50
19 Nov 2020 13:07
GUSTAVO56 schrieb:
Could you provide more details about the size of the furniture, whether it stands free or against the wall, and how uneven the floor is?
Thank you for your detailed reply! The furniture pieces are each about 180 cm (71 inches) wide and approximately 40 cm (16 inches) deep. So far, I haven’t fixed them to the wall because I want to use them as free-standing room dividers. The floor is parquet, which is generally quite level, but slight slopes or minor unevenness might be possible. Internal cross braces are an option in principle, but they shouldn’t be too complicated since I might want to move the furniture around occasionally. Are your recommendations still feasible if the furniture is moved from time to time?
