ᐅ How can I refurbish MALM furniture after years of use?
Created on: 18 Oct 2021 21:07
Tazar
Tazar
18 Oct 2021 21:07
Hello everyone, I have a question that some of you might be familiar with: How can I restore or freshen up my Malm furniture, which I have been using for several years, without damaging the character of the surface? Specifically, I am referring to the white versions with the laminate coating, which typically develop small scratches, dull spots, and discoloration after prolonged use. These surfaces don’t seem suitable for sanding, as they don’t have a real wood layer but rather a thin laminate. Are there gentle methods to make the furniture look good again, perhaps using special care products or techniques? I have considered furniture polish but am unsure if it might cause damage or soften the laminate. I would also be interested in home remedies or professional approaches. Thanks for your tips and experiences!
Elias
18 Oct 2021 21:53
Hello Tazar, I can totally understand how frustrating it is when beloved furniture shows signs of wear after many years of use.
Tazar schrieb:
how can I restore or refresh my MALM furniture, which I have been using for several years, without damaging the character of the surface?
That’s a really tricky situation, especially because MALM furniture is coated with a veneer, as you correctly pointed out. I once tried to bring a piece of furniture like that back to a glossy finish and found that sanding is not an option because the veneer gets damaged very easily. Instead, I started carefully with mild cleaners and then used a special plastic care product sold in hardware stores as “furniture foil care.” This helped reduce minor scratches and made the surface look fresher again.
What I also recommend: try it first on an inconspicuous spot and let the product soak in well – patience pays off. If you want to try furniture polish, avoid products with solvents, as they can dissolve or cause the veneer to wrinkle.
Maybe other users here have additional tips. I wish you the best of luck in loving your MALM furniture again soon 🙂
Laukau5
19 Oct 2021 09:29
Hello Tazar, I find your question about refreshing MALM furniture surfaces very interesting and important, because coated furniture is often treated incorrectly.
Elias schrieb:
Sanding is not possible because the laminate damages easily.
That is absolutely correct, as the laminate is usually only 0.1 to 0.3 millimeters (0.004 to 0.01 inches) thick, which means any mechanical sanding would be immediately visible—most of the time this leads to unsightly spots or even complete damage.
My recommendation is a systematic approach in several steps:
1. Cleaning: Use a mild, pH-neutral cleaner (e.g., specific plastic cleaners) and soft microfiber cloths. Avoid strong chemicals!
2. Scratches: Small, superficial scratches can be treated with specially designed plastic polish products that contain fine abrasive particles. However, this requires a delicate touch, as excessive polishing can cause the surface to become dull or spotted.
3. Protection and care: Finally, it is advisable to apply a plastic care wax or a maintenance spray designed for laminate furniture. Their ingredients visually smooth the surface and protect against new dirt.
A few tips: Always work with slightly damp cloths and test products first on hidden areas. If you have larger damages, unfortunately, the furniture parts might need to be replaced.
How do your furniture surfaces look? Are they mostly small scratches, or are there also areas with slight laminate peeling? That could be relevant for choosing the method.
Seanni
20 Oct 2021 14:41
Hey Tazar, I wanted to join the conversation – refurbishing MALM furniture is definitely a delicate task, but there are some neat tricks that have brought my pieces back to life 😉
Laukau5 schrieb:
Specialized plastic polish products contain fine abrasive particles.
I completely agree – in my experience, you really need to be very gentle. I like to start with a soft household sponge (not a scratch sponge) and clean the surface thoroughly using a mild dish soap mixed with warm water. Then gently blot dry, don’t rub!
After that, I apply a very light plastic polish, which I got from a specialist auto accessory store – it really brings back the shine after just a few minutes without damaging the laminate.
One more tip: sometimes a simple furniture care cream or oil combo can help, but use it sparingly and not too often, otherwise it gets greasy 😉
If you feel like it, try it step by step and be patient. Your MALM furniture deserves to look great again! 🙂
