ᐅ How can I permanently stabilize MALM furniture?
Created on: 11 Feb 2023 08:13
Trapo36
Trapo36
11 Feb 2023 08:13
Hello everyone, I have several MALM furniture pieces from IKEA, including dressers and cabinets, which have started to feel somewhat unstable over time. My question is: How can I permanently reinforce MALM furniture without affecting its appearance or functionality? I’m especially interested in which reinforcements have proven effective in furniture construction and whether there are any model-specific tips or tools recommended. What bothers me most is the wobbling when pulling out the drawers and the tendency of some shelves to twist slightly. Who can share advice on the best way to address these issues?
KARJU
11 Feb 2023 08:47
Trapo36 schrieb:
How can I permanently stabilize MALM furniture without affecting its appearance or functionality?
To stabilize MALM furniture, a combination of the following measures is recommended:
1. Use metal angle brackets to reinforce the back panel. Often, the back panel made of thin particleboard is too weak.
2. Replace the supplied nails with screws, especially for corner joints.
3. Add diagonal braces on the back if possible, to prevent twisting.
4. Check and, if necessary, replace the connecting fittings, as IKEA fittings can loosen with frequent use.
5. Apply high-quality wood glue (e.g., Ponal) at the joints for durable bonding.
It is important to proceed carefully during all work to avoid affecting the furniture’s appearance.
kaubi
11 Feb 2023 09:19
KARJU schrieb:
Use of metal angle brackets to additionally secure the back panel.
This is exactly where the problem lies with MALM: the back panels are often just thin HDF boards that offer little stability. I recommend removing the back panel and instead using a 3-4 mm (1/8 inch) thick plywood sheet, cut to the original dimensions and fixed with several small stainless steel screws.
KARJU schrieb:
Addition of diagonal braces on the back,
if space allows, these can be made from slim metal profiles or even wooden slats. They effectively prevent tipping and twisting, especially in dressers with drawers.
I would be interested to know whether you plan to reinforce the furniture permanently or are just looking for a short-term fix.
Trapo36
11 Feb 2023 11:05
kaubi schrieb:
I’m curious whether you plan to reinforce the furniture permanently or are just looking for a short-term fix.
Thanks, that’s an important question. I prefer a durable, sturdy solution because I move the furniture frequently and it’s also used by children. Appearance is important to me, but some visible reinforcement would be acceptable if it improves stability. I’m not interested in constantly tightening screws or pushing parts back into place. That’s why the idea of reinforced back panels sounds good. Tips on optimal material thickness and screws would be helpful.
SauDietmar
12 Feb 2023 12:37
Here is a brief guide for the long-term stabilization of MALM furniture:
1. Remove the original back panel. The thin chipboard will not hold up well over time.
2. Cut a new back panel, for example from 4 mm (5/32 inch) plywood, which is stable and lightweight.
3. Attach it evenly with small screws (3.5 x 16 mm / 1/8 x 5/8 inch) to avoid pressure points.
4. Additionally, install corner braces in the corners, which can be found at hardware stores, for example 30 x 30 mm (1 1/8 x 1 1/8 inch) galvanized brackets.
5. Regularly lubricate the drawer slides and secure the drawers internally with glue to prevent twisting.
Note: MALM furniture often uses Minifix connectors; avoid using screws that are too large here. Instead, reinforce the original fittings with glue.
Summary: Stability is achieved through a solid back panel, additional corner braces, and preventing loose clamp joints.
theo63
12 Feb 2023 16:44
Is this really beneficial for stability, or just for smooth operation?
I’m asking because I’m considering whether stabilizing the drawers mechanically with additional cross braces might be a better solution than relying solely on lubrication.
Also: In your opinion, how durable is the use of wood glue with these particle boards? Doesn’t it lose strength if the furniture is exposed to moisture?
My suggestion would be to reinforce the most heavily loaded joints with small metal plates. That might help to keep the structure intact over time.
