ᐅ How can I permanently eliminate the squeaking noise from Malm furniture?
Created on: 13 Sep 2020 18:23
sautau
I have a problem with my Ikea Malm furniture, specifically the drawers that constantly squeak when I open or close them. It’s quite annoying, especially since there doesn’t seem to be a particular reason – the furniture is only about two years old and hasn’t been heavily used.
I have already tried taking the drawers apart and reassembling them, as well as applying some silicone spray to the drawer slides, but the effect was only temporary.
My question is: how can I permanently eliminate the squeaking in Malm furniture drawers? Are there any proven methods that work long-term without damaging the furniture? I would prefer not to replace any parts if there is a simple solution.
Thank you for your tips and experiences!
jelite
14 Sep 2020 15:27
kla65 schrieb:
If the squeaking continues after lubrication, check the screws and connections of the drawers and runners.
This is an important detail, thanks kla65!
In addition to the screws, you should also ensure that the drawer slides are straight and not warped. A slightly bent rail often leads to uneven stress and unwanted noises.
The material between the runner and the furniture frame (such as rubber bumpers or small felt strips) can also help absorb shocks and reduce noise.
In conclusion: Eliminating noise usually involves a combination of cleaning, lubrication, adjustment, and mechanical inspection.
Kyler10
15 Sep 2020 09:11
In summary, from a technical perspective:
The main issue with Malm drawers squeaking is often caused by dirt and lack of lubrication at wood-plastic interfaces.
To address this permanently, I recommend the following steps:
- Thorough cleaning, possibly using isopropanol.
- Application of a PTFE-based lubricant.
- Mechanical inspection and adjustment.
- Treatment of the wooden contact surfaces with special furniture wax or paraffin.
Combining these measures will reliably help improve the function in the long term.
sautau
15 Sep 2020 18:54
Hello and thank you very much for the numerous tips and the exchange!
I will start cleaning and lubricating tomorrow, paying special attention to the recommended dry lubricants. I will also check the adjustment of the screws and any small mechanical tweaks that might be needed.
I’m happy to report back on whether and how it helped. It’s reassuring to now have a clear understanding of the causes and possible solutions.
Thanks again for the detailed explanations and advice!
