ᐅ How can I paint IKEA Hemnes furniture without damaging its original texture?
Created on: 13 Oct 2023 08:37
V
Vinkau62
Good morning everyone,
I want to paint an IKEA Hemnes piece of furniture, but I’m concerned about damaging its distinctive wood texture and fine grain. My question is: How can I paint a Hemnes effectively without harming or altering the original wood or surface structure? Are there special techniques or materials that allow painting while preserving the visual depth of the texture, without completely covering the surface?
I think tips on sanding methods, suitable primers, or specific types of paint would be very helpful. It’s especially important to me that the wood’s visual dimension is maintained, as the grain is a major part of the furniture’s charm.
I look forward to your experienced advice and suggestions!
I understand the concern about preserving the natural grain, and I’ve personally had doubts about painting a Hemnes shelf before.
[quote=Nathanaelk, post: m9s1q9, member: XXX]It is important not to over-sand the surface, as this can cause the grain to be lost.
I can only agree with that. I once sanded too much – the surface looked smooth afterward, but it appeared flat and dull.
Taking your time and applying several thin coats of finish is key. I’ve had good experiences with a satin clearcoat because it doesn’t look too sterile; instead, it maintains some warmth in the wood.
If you’re unsure while sanding, you can use painter’s tape and work on small sections to get a feel for how much sanding is appropriate.
It may be nerve-wracking, but the results are worth it when you proceed carefully.]
Vinkau62 schrieb:
How can I paint a Hemnes piece well without damaging or altering the original wood grain or surface texture? Are there special techniques or materials that allow painting while preserving the visual depth of the grain, without completely covering the surface?Simply use wood stain with a brush, not an opaque paint. This way, the texture remains visible. Avoid applying it too thickly.
Hey,
I think the whole approach of sanding a lot and applying thin layers sounds very technical, but you should also enjoy the project a bit. Hemnes is sturdy, so stay relaxed.
My tip:
- Lightly sand
- Use a matte water-based varnish (e.g., acrylic water-based paint)
- Apply thinly with a sponge or brush
- Don’t forget to sand between coats, it really gives a nice finish.
I can confirm, this really works well.
You don’t have to take everything too seriously, practice makes perfect!
My tip:
- Lightly sand
sinhau schrieb:
The result is a matte, protective film that leaves the wood surface visible while highlighting the texture instead of covering it up.
