ᐅ How can I paint IKEA Hemnes furniture without damaging its original texture?
Created on: 13 Oct 2023 08:37
V
Vinkau62
V
Vinkau62
13 Oct 2023 08:37
Good morning everyone,
I want to paint an IKEA Hemnes piece of furniture, but I’m concerned about damaging its distinctive wood texture and fine grain. My question is: How can I paint a Hemnes effectively without harming or altering the original wood or surface structure? Are there special techniques or materials that allow painting while preserving the visual depth of the texture, without completely covering the surface?
I think tips on sanding methods, suitable primers, or specific types of paint would be very helpful. It’s especially important to me that the wood’s visual dimension is maintained, as the grain is a major part of the furniture’s charm.
I look forward to your experienced advice and suggestions!
gasidney
13 Oct 2023 09:15
If the wood structure is to be preserved, use a wood stain finish instead of an opaque paint.
Technically, only lightly sand the surface and then apply a thin layer of stain.
Clear varnish is also better than colored opaque paints.
Curtis
13 Oct 2023 10:02
I wonder if the structure of a painted piece of furniture really remains intact when using paint instead of stain. In my opinion, an opaque paint clogs the pores and visually eliminates the grain.
Why not work directly with a transparent or semi-transparent oil? That preserves both structure and protection at the same time.
Also: Does anyone have reliable experience specifically with Hemnes? These often come with a type of protective finish already applied.
Nathanaelk
13 Oct 2023 11:47
to preserve the original texture of the IKEA Hemnes during painting, the process must be carefully planned:
- First: Since the Hemnes is usually painted or stained, lightly sand the surface with fine sandpaper (grit 220–320) just enough to roughen it for the new paint without smoothing out the texture.
- Primer: Use an acrylic-based wood primer that is transparent or lightly tinted to maintain the depth effect.
- Paint type: A transparent or satin-finish acrylic paint is best, possibly applied in thin layers with a spray gun or fine rollers. Thick layers of topcoat tend to create an even surface that hides the texture.
- Intermediate sanding: After each coat, sand lightly with very fine sandpaper (grit 320+) to achieve a smooth surface without blurring the wood texture.
- Finish: A clear topcoat can protect the surface and visually enhance the texture.
It is important not to sand the texture excessively, as this will erase the grain. Also, applying paint layers that are too thick is counterproductive.
One more question: Which exact piece of furniture is it? Fronts, carcass, or tabletop? This also influences the choice of materials and techniques.
V
Vinkau62
13 Oct 2023 12:13
[quote=Nathanaelk, post: m9s1q9, member: XXX]One more question: Which exact piece of furniture are we talking about? Front panels, carcass, or tabletop? This also matters when choosing the material and technique.
Thank you for the detailed response. Specifically, it concerns the doors and drawer fronts of a Hemnes wardrobe. The surfaces are fairly flat with a slightly raised border. The inner surfaces and the back remain untouched. The goal is a matte, light color that doesn’t simply cover with white paint but allows the wood grain to remain visible.
sinhau
13 Oct 2023 13:29
I can recommend a simple step-by-step guide on how to apply paint while preserving the texture:
Step 1: Prepare the material – lightly sand the Hemnes with 320-grit sandpaper without smoothing the surface too much.
Step 2: Remove dust – use a microfiber cloth or a dust brush.
Step 3: Choose a thin, translucent wood varnish (acrylic-based with a matte finish). Avoid thick, opaque coatings.
Step 4: Apply the varnish thinly with a fine foam roller or a soft-bristle brush – the wood grain should remain visible.
Step 5: After the first coat, let it dry thoroughly, then very lightly sand with 400-grit sandpaper to remove any unevenness.
Step 6: Apply a second thin coat of varnish.
Tip: Always brush in the direction of the wood grain, and if possible, use a spray gun for an especially even application.
The result is a matte, protective film that keeps the wood surface visible while highlighting the texture instead of covering it.
I recommend testing on an inconspicuous spot or a sample piece of wood.
