ᐅ How can I paint BILLY shelves without causing any damage?
Created on: 12 Jan 2024 18:37
kinkeo47
kinkeo47
12 Jan 2024 18:37
I am planning to paint my BILLY shelves from IKEA, but I definitely want to avoid damaging the surface or compromising the stability of the shelves. The shelves are made of particle board with a foil coating, and I am wondering what the best approach is to apply paint that will last long-term without damaging the material.
I have read a lot already, but most advice refers to solid wood or painted surfaces. What kind of surface preparation is recommended in this case? Are there certain types of paint that won’t damage the foil, or is it better to lightly sand the surface before painting?
I would appreciate detailed tips on the appropriate sanding method, the choice of paint and finish, as well as the ideal preparation of the material. Has anyone had experience with a durable and damage-free color change on BILLY shelves? Thanks in advance!
Filippo
12 Jan 2024 19:05
Hello kinkeo47,
first of all, a good approach to formulate the question so precisely. BILLY shelves often consist of laminated particleboard, which makes the process a bit more complicated than solid wood.
It is important not to damage the foil surface too much. I recommend the following procedure:
1. Cleaning: Start by using a non-greasy cleaner to remove dust, grease, and other contaminants. Simply wipe down with alcohol or methylated spirits.
2. Sanding: The surface should be lightly roughened so the paint adheres better. Use fine sandpaper (grit 220-320) and apply light pressure. You definitely do not want to sand through the foil.
3. Priming: Choosing the right primer is crucial here. For smooth plastic surfaces or foil, a bonding primer based on acrylic paint is recommended, as it improves adhesion while protecting the material.
4. Painting: Acrylic or alkyd paints are often suitable. Make sure to apply thin layers and allow each coat to dry thoroughly. Spray paint can create an even finish but requires good ventilation and careful preparation.
5. Sealing: Finally, apply a matte or satin clear coat with UV protection to increase durability and make the surface resistant to scratches.
One more question: How much use is expected for the shelf – mostly decorative or for heavy loads? That will affect the type of paint and the thickness of the layers.
Filippo
klo61
12 Jan 2024 19:43
Filippo schrieb:
First, use a non-greasy cleaner to remove dust, grease, and other contaminants. Simply wipe down with alcohol or denatured alcohol.
This is a very important step! I would add that after sanding, you should thoroughly remove all sanding dust, for example with a slightly damp cloth or an anti-static dust cloth – even the smallest dust particles can cause the paint to become uneven.
Filippo schrieb:
The surface should be lightly roughened to ensure better paint adhesion. Use fine sandpaper (grit 220-320) and apply light pressure.
Please do not sand too hard, because if the film is damaged, it may shrink or peel off later.
Regarding painting itself: I recommend using a spray paint can with a special adhesion primer for plastic or films if you don’t have a spray gun. Hardware stores carry special adhesion primers for challenging surfaces, which can help create a durable bond.
Always allow each coat of paint to dry well, and start with several thin layers rather than one thick one. This reduces the risk of drips and unevenness.
To finish, you can protect the paint with a suitable clear coat – this will extend the durability and make it easier to clean.
Hope this helps you!
Lucien
13 Jan 2024 08:29
klo61 schrieb:
Please avoid sanding too aggressively, as damaging the foil will cause it to shrink or peel off later.
This warning is essential from a technical perspective: the laminate on the BILLY shelves is only a few tenths of a millimeter thick. Aggressive sanding can destroy the protective layer and damage the particleboard underneath, leading to blistering and eventual peeling.
I recommend the following minimum standard:
- Sand with 320-grit sandpaper, applying only light to moderate pressure.
- Avoid eccentric sanding that creates local grooves.
Regarding the paint:
- Water-based acrylic paints are environmentally friendly and provide good adhesion.
- Matte or satin finishes create a surface that better hides minor signs of wear.
Finally, a note on environmental safety:
- Wear a protective mask at all stages, especially when sanding and painting.
- Work in well-ventilated rooms or outdoors.
If you follow these guidelines, the risk of damage should be minimized.
bapar
14 Jan 2024 10:17
Lucien schrieb:
Water-based acrylic paints are advantageous both environmentally and in terms of adhesion.
I agree with this and would like to point out an additional preparation step that many underestimate:
Before sanding and priming, it is advisable to perform a micro-fine smoothing using a scouring pad or very fine sandpaper, so that only the very top layer is minimally roughened without penetrating the laminate.
This can make a significant difference, especially with BILLY shelves featuring high-gloss laminates, as it affects whether the paint will adhere properly or not.
Also: patience during drying is crucial. Accelerators or too short drying times often lead to bubbling or poor adhesion.
kinkeo47 schrieb:
What surface pretreatment makes sense, do certain types of paint damage the laminate, or is it better to slightly roughen it before painting?
Here is my advice again: make sure to only lightly roughen the surface and use a special primer designed for laminated boards or plastic laminates. It may help to do a test on an inconspicuous spot first—trying out different primers can provide clarity.
How much wear has your shelf experienced so far? Is there a high risk that it will be touched frequently or that items will be placed on it that could cause scratches? This will influence how thick the paint layers should be.
