ᐅ How can I pack IKEA Brimnes furniture in a way that is easy and safe for transport?
Created on: 15 Feb 2022 09:27
gubebo
gubebo
15 Feb 2022 09:27
I am planning to move some IKEA Brimnes furniture soon—specifically a wardrobe, two dressers, and a bed frame—and I am looking for good tips on how to pack these pieces securely for transport. It is important to me that they are well protected, that the individual parts remain as compact as possible, and that the packaging makes handling easier during the move.
Does anyone have experience with Brimnes furniture or similar IKEA furniture construction? What materials or methods do you recommend to prevent scratches, dents, or moisture damage during transportation?
I would appreciate practical, detailed advice—such as on disassembling, padding, packing materials, or securing essential parts.
Thank you in advance!
TRA33
15 Feb 2022 09:45
Disassemble the Brimnes furniture completely beforehand to pack it in a space-saving way.
Wrap all wooden parts with bubble wrap and secure it with painter’s tape. Additionally, furniture blankets help to cover the pieces. Collect screws and small parts in small bags, which are best attached to the corresponding parts.
This way, you avoid scratches and don’t lose any components.
Dopoki
15 Feb 2022 10:11
For packaging IKEA Brimnes furniture for transport, I recommend the following steps:
- Completely disassemble the furniture to prevent damage from movement.
- Carefully wrap each wooden piece with special padding film or multiple layers of bubble wrap.
- Reinforce the interior surfaces, which are particularly sensitive, with cardboard sheets.
- Collect screws, dowels, and small parts in labeled bags and, ideally, attach them to the corresponding pieces.
- Bundle the furniture parts with straps or ropes to prevent shifting during transport.
- Use moisture protection film if exposure to moisture during transport is expected.
This approach effectively protects the furniture from scratches, splinters, and warping.
Ianlau
16 Feb 2022 07:33
Hello gubebo,
I understand your concern well, since IKEA furniture like Brimnes is solid but can be quite delicate during transport. That’s why good packaging is essential.
In addition to the secure disassembly and padding with bubble wrap or furniture blankets you already mentioned, I would like to highlight the following points:
- Make sure all edges and corners are especially protected, as they are the most vulnerable to damage. Cardboard edge protectors or cut pieces of foam are very helpful here.
- If you don’t have furniture blankets, a thick blanket or old rugs can also work to gently cover surfaces and absorb shocks.
- Always pack smaller parts (screws, dowels, handles) separately and well-labeled, preferably in a small bag attached to the largest matching panel during transport, so nothing gets lost.
- It is also important that the packed parts are placed as tightly as possible in the car or van without room to move, as shifting can cause scratches or breaks.
I hope these tips help you. If you want, I can also share a specific example of how I handled this when moving a Brimnes wardrobe.
Layla
16 Feb 2022 21:05
Ianlau schrieb:
It is also important to place the packaged parts in the car or van as tightly as possible without any room to move, because shifting can cause scratches or breakage.
I can definitely confirm this. Last year, I transported my Brimnes wardrobe and realized how important it was to secure and cushion the parts. At first, I was worried that all the packaging material would make everything too heavy, but without protection, I shouldn’t have done it—it would have been really frustrating if anything had been damaged.
I also found it helpful to add padding not only at the corners but also on flat surfaces, especially because the surface can get scratched easily otherwise.
So my advice is: invest a little extra time in packing, and you’ll have less stress during the move and can look forward to setting up your furniture again.
