ᐅ How can I make the installation of Ikea Metod cabinets easier to organize?
Created on: 21 Nov 2017 19:03
hugopo
Hello everyone, I am currently planning my kitchen using the Ikea Metod system and want to keep the assembly as efficient and stress-free as possible. Since I already have some experience with furniture assembly, I am specifically wondering: What organizational approaches and helpful methods would you recommend to better structure the assembly process of the Ikea Metod kitchen cabinets and to prevent common issues? For example, I am thinking about a sensible workflow, tool selection, time management, or work distribution when multiple people are involved. I look forward to practical tips, experiences, and strategies that can make the installation easier and faster.
fidasi
21 Nov 2017 20:09
The organization of assembling the Metod system is indeed a complex process that requires detailed preparation. Here is my approach: 1. Planning: I measure the rooms and create a precise assembly plan with all measurements and positions in advance. 2. Sorting: All packages are opened, and parts are separated by function (cabinets, doors, drawers). This is recommended because screws often look similar, helping to avoid mistakes. 3. Assembly order: Build the cabinets first, then push them together and align them. It is important to follow the level carefully to prevent issues with doors and drawers later on. 4. Tools: Cordless drill with torque control, sufficiently long drill bits, rubber or felt pads for delicate surfaces. 5. Helpers: I assign roles. One person holds, one screws, and one measures. This makes the work more efficient. 6. Time planning for me is based on 4–6 hours per unit (depending on experience). 7. Inspection steps: After each major section, I check the fit and review the instructions again to minimize errors. Please feel free to tell me where your biggest uncertainties are during the assembly so I can give you more targeted advice.
hugopo
21 Nov 2017 20:25
fidasi schrieb:
You could tell me where your biggest uncertainties are during assembly, so I can give more targeted advice.
Thank you for the detailed post! My main uncertainties are – the exact alignment of the cabinets, as I would prefer not to have to undo everything again – two people will help with the assembly, but I wonder whether it makes more sense for them to work simultaneously on different furniture pieces or to stay coordinated on the same piece – also, I’m concerned that I might damage the protective coating when pre-drilling or screwing. Are there any special tips for this?
Jonna62
21 Nov 2017 20:40
A tip for leveling: always use a spirit level and small spacers. Some also use small wedges to make fine adjustments easier during alignment. Regarding helpers: the process is easier and faster when two people work together on a piece of furniture, but with clearly divided tasks (one holds, the other screws).
erwinan
22 Nov 2017 07:12
Material Protection: Pre-drill with a drill bit that has a smaller diameter than the screw. Insert screws carefully, do not tighten too much, as this often causes the surface to crack.
naujon
22 Nov 2017 08:54
For assembly organization, I recommend the following workflow:
- Preparation: Unpack all parts and sort them by category.
- Set up the workspace: Clean, well-lit, and with enough space.
- Prepare tools: Cordless screwdriver, spirit level, screwdriver, drill, tape measure.
Then assemble the carcasses step by step:
- One helper holds the component while the other screws it in.
- Check regularly with the spirit level.
Tips for screwing:
- Always pre-drill if you are unsure.
- Screw in slowly and straight to avoid damage.
Time management:
- Plan at least 2 days, better more than too little.
In summary, a well-structured process and clear task distribution significantly simplify assembly.
ladali
22 Nov 2017 09:36
Jonna62 schrieb:
A tip for alignment: Always use a spirit level and small spacers.
This is an important point. I would add that small wooden or plastic wedges are suitable for holding temporary gaps very precisely.
erwinan schrieb:
Material protection: Pre-drill with a drill bit that is smaller in diameter than the screw.
This method prevents cracking and splitting. Additionally, starting lightly at less visible spots can be useful to test the material.
