ᐅ How can I make the best use of Ikea Platsa furniture in small apartments?
Created on: 23 Dec 2023 10:37
Ben36Hello everyone,
I am currently planning to furnish my small apartment with Ikea Platsa furniture and am looking for tips and tricks on how to use this series in a space-saving yet functional way. The Platsa systems seem very suitable due to their modular and versatile elements, as the individual units can be combined and stacked.
My apartment is only about 25 meters squared (270 square feet), and I want to avoid having the furniture overwhelm the space, while still needing enough storage for clothing, household items, and occasionally guests.
Does anyone have experience with optimizing Platsa in small apartments? For example:
- Which combinations are sensible to make the best use of the available space?
- Are there smart ways to gain storage in unusual niches, corners, or areas under the ceiling?
- How do you manage doors in a small room – open or closed?
- Does anyone know practical tricks for rearranging the modules flexibly as needed?
Thank you in advance for your detailed recommendations!
Ben36 schrieb:
I am currently planning to furnish my small apartment with Ikea Platsa furniture and am looking for tips and tricks on how to use this series in a space-saving yet functional way.That’s already a great plan! Platsa is really like Lego for adults 😄. Especially in small apartments, you can get a lot out of the modular design. My advice: Use closed units at the bottom for storage so nothing is left out in the open, and place open shelves above to keep the space from feeling heavy.
- Make good use of the height! Stackable modules are your best friend if the ceilings aren’t too low.
- Corner units fit perfectly in corners—they are available in the Platsa series and help you make use of otherwise wasted space.
- In my opinion, doors are a must if your storage options are limited—open units look airy but only work if you keep everything well organized.
One more tip: I added baskets to some compartments. This way, you can store stuff neatly, and it makes the space feel cozier and less “furniture-like.” Good luck, and let us know which combination you decide on!
dijan schrieb:
Use height above all! Stackable modules are your best friendHere, I want to go into a bit more technical detail: Platsa modules offer great flexibility thanks to their standardized dimensions of 40x40 cm (16x16 inches). To make the most of your 25 m² (270 sq ft), you should not only focus on height but also carefully plan the depth and door opening direction.
Some tips for optimal use in small apartments:
- Measure your walls precisely. Since Platsa modules can be quite deep (up to about 55 cm (22 inches)), depending on room depth you can also choose shallower or open versions that take up less hallway space.
- Installing Platsa against walls prevents tipping when stacking higher (caution: always use appropriate wall plugs/anchors!).
- Use doors with hinges that require less opening space in tight rooms (e.g., sliding doors are not available in the range, but you can at least arrange some cabinet doors to open outward).
Also: To allow easy modification of furniture functions, you can assemble modules from several smaller sections, which can be adjusted individually later—e.g., some sections for clothing storage, others for electronic devices.
I’m curious where exactly in your apartment or on which wall you plan to install Platsa, so we can provide more targeted advice.
Ben36 schrieb:
How do you handle doors in small rooms – mostly open or closed?In general, I would recommend doors for a small apartment, as they help create order and calm the overall look. Open shelves or compartments work best if you keep things very tidy and don’t have many small items lying around.
A few tips:
- If you store items that change frequently (e.g., seasonal clothing), doors are definitely more practical.
- With open units, you can use baskets or boxes to organize storage visually, but the shelves still need a clear system.
- Consider having some Platsa units with doors and others left open. That way, you get both quick access storage and closed space for hiding clutter.
Furniture placement is also important:
- In the living area, more open to create a feeling of lightness.
- In the bedroom or hallway, preferably closed to keep everything tidy.
Good luck with your planning!
GOLO42 schrieb:
I’m curious about which corner or wall you specifically plan to install the Platsa onThis is an important point. For Platsa in small apartments, there are often unusual niches or awkward long walls that are not perfectly rectangular. Here is my structural suggestion for installation:
1. Planning
- Start with precise measurements (height, width, and depending on ceiling height, also up to the ceiling surface)
- Take into account radiators, electrical outlets, and light switches that might affect placement
2. Module Selection
- Use shallower modules for narrow hallways or tighter spaces
- Corner modules and multi-pack combinations to utilize narrower side areas
3. Installation
- Wall mounting for stability
- Possibly drill additional holes in the back panel if cable management is planned
4. Functionality
- Combine closed compartments for shoes, clothing, and household items
- Open shelves for books, plants, or decorations to avoid making the space feel cramped
Summary:
It makes sense to combine a versatile modular system with various depth and height options that you can build and adjust at any time. It’s important to consider the space itself—especially in small apartments, every centimeter (inch) counts.
If you like, we can also discuss specific floor plans you have!
