Hello everyone, I’m looking for ideas and practical tips on how to optimize the IKEA Brimnes furniture series specifically for small spaces. My apartment is quite compact, and I find it challenging to arrange and, if necessary, adapt the furniture to make the most efficient use of the space while still maintaining a pleasant atmosphere. I’m especially interested in how to maximize storage without increasing the feeling of tightness, and whether there are any useful combinations or additions within the range that integrate particularly well. I’m looking forward to your experiences, tricks, and perhaps some unconventional solutions!
A good approach to optimizing Brimnes furniture in small rooms is to first carefully assess the functions of each piece. The range includes several multifunctional items – for example, beds with built-in storage and dressers that can be effectively combined with shelves. A common tip is to avoid choosing furniture that is too wide and instead focus on vertical storage, using shelves or tall cabinets.
Additionally, the room layout should be planned carefully before purchasing. Tape measures and sketches are helpful to ensure no space is wasted. The Brimnes collection is fairly modular, so it can be useful to combine pieces, such as a low bed with pull-out drawers underneath. This creates extra storage space without needing to add more furniture to the room.
Vinlen schrieb:
Optimizing Brimnes furniture in small rooms means first carefully evaluating the functionality of each piece.That is an important point. I would add that in small rooms, it is even more crucial to consider how the furniture fits with the room dimensions. Brimnes furniture is relatively compact, but the height and modular flexibility are key factors. For example, the Brimnes bed with two drawers underneath can serve both as storage and as space for seasonal clothes or bedding, reducing the need for additional wardrobes. A common challenge here is the drawer height: they should be easily accessible without the need to bend down or stretch awkwardly.
Furthermore, I recommend paying attention to varying depths when using shelves and dressers. For instance, narrower shelves can be mounted on walls to keep the room visually open. Brimnes dressers can often be complemented with other storage furniture from IKEA, such as storage boxes that fit perfectly inside.
It gets even more detailed when considering lighting conditions: the white surfaces of the Brimnes series reflect light well and make small rooms appear larger. Adding extra LED spotlights or light strips in darker corners can make the furniture arrangement feel more spacious.
I’m interested to know: What is your exact room situation? Are there corner areas or niches that are particularly tricky? Are there limitations regarding furniture color or the existing floor? This information could help to provide more specific suggestions.
bapar schrieb:
I’m curious: What exactly is the room layout like? Are there corner areas or niches that are especially tricky?Good question! Corners are often the biggest unknowns in a small room maze 😅. My tip: Use angled inserts or corner shelves if Brimnes doesn’t fit perfectly. Sometimes you also have to intentionally "break up" the furniture, for example by placing two narrower dressers instead of one wide one, leaving gaps for air circulation and a more open feeling.
You should definitely try the "less is more" approach in small rooms. The Brimnes series is quite simple in design—perfect for setting up minimally with only the essential pieces, so the room doesn’t feel overcrowded.
Oh, and another little trick from my side: Use the back of drawers or cabinet doors for bottle openers or small hooks to really maximize existing storage space—so-called "invisible" storage. I find that super practical and not very well known!
You need to approach small spaces boldly. There’s no room for rigidly aligned furniture rows; better to try diagonal or "tilted" arrangements—it looks a bit wilder but often makes better use of creative corners.
