ᐅ How can I optimize the assembly of the IKEA BRIMNES furniture when short on time?
Created on: 11 Apr 2021 07:23
neogusta70N
neogusta7011 Apr 2021 07:23Good morning everyone, I am facing the challenge of assembling an IKEA Brimnes wardrobe, but due to my very tight schedule—sometimes only 1.5 hours per day—I don’t have much flexibility. I generally find the instructions clear, but the assembly process could definitely be faster and more efficient without compromising the quality of the build. My question is: How can I optimize the IKEA Brimnes assembly when I’m short on time, so that I can not only work quickly but also ensure the wardrobe is sturdy and secure? Are there any proven tips or useful priorities in the assembly steps that could save time? I’m looking forward to your recommendations and what has worked well for you!
Hello neogusta70, your concern is very understandable and applies to many first-time furniture buyers who cannot spend hours on assembly. I always recommend unpacking everything first and sorting the parts and tools carefully before starting the actual build. This helps avoid searching and mixing up pieces later. It’s also useful to flip through the instructions step by step beforehand and mentally review each stage. With BRIMNES, for example, you can usually work on the larger modules in parallel if you have, say, two days: for instance, the frame on Monday and the drawers on Tuesday. This way, you set clear, manageable goals that you can realistically achieve within the available time. Patience is helpful as always – the result will be neat and sturdy assembly.
Based on my experience with many IKEA furniture pieces, I recommend breaking down the assembly process into smaller micro-steps. Especially with the BRIMNES, which uses several similar components, it makes sense to sort these beforehand. This saves time and helps avoid mistakes. Here is a possible workflow: - Sort components by type (shelves, side panels, screws) - Divide the instruction steps into logical sections - Prepare tools (screwdriver, hammer) - Keep screws and dowels within easy reach in a small box - Fully assemble drawers before inserting them and check their function Another tip: if possible, use a cordless drill with torque control – this speeds up the process significantly and prevents over-tightening the screws. Finally, a question for you: do you have a helper or are you working completely alone? Based on that, I can offer more specific time management advice.
neogusta7011 Apr 2021 11:05TEBILO schrieb:
Finally, one more question for you: Do you have a helper or are you working completely on your own? Based on that, I can provide more specific time management tips.Thank you for the valuable insight, TEBILO. I mostly work alone since my partner has other priorities, and I prefer to keep control myself. What adjustments do you recommend for working solo, especially regarding the often cumbersome parts of the BRIMNES?
An important addition to the previous tips: If you are working alone, be sure to pay attention to the assembly sequence to avoid unnecessary repositioning or regrouping. Bulky parts can be prepared very well on a soft surface (e.g., carpet or blanket) before standing them up. Another tip: Separate screws into small bags labeled or numbered according to each assembly group – this significantly reduces searching time, even when working alone. And if you stumble at any point, avoid hasty corrections – these often take more time than a focused, slower second attempt.
I completely understand how stressful lack of time can be during a project like this, as I’ve experienced it myself. What helps me is mentally celebrating small achievements. So if you have days where you only assemble one wall, that’s still a good step forward. Also, make sure to take breaks and immediately put away anything you no longer need to keep things organized. At the same time, breaks help you gain fresh perspectives for the next phase. If you ever feel uncertain along the way, let us know exactly where – maybe a second opinion can help you without having to spend a lot of time figuring it out.
