ᐅ How can I best set up Ikea Pax wardrobes for a home office?
Created on: 2 Feb 2024 08:17
garudi
Hello everyone, I want to optimize my Ikea PAX wardrobe for my home office and am looking for tips on how to get the most out of this piece of furniture. The goal is to create as much storage space as possible while maintaining a functional and organized setup for office supplies, documents, and tech accessories. It is also important to me that everything remains easily accessible and that the wardrobe looks tidy at the same time. The dimensions of the PAX are approximately 150x201x60 cm (59x79x24 inches). Does anyone use PAX for their home office and can offer specific recommendations for interior fittings such as drawers, shelves, hanging rods, or particularly for cable management? Any advice on ergonomic aspects would also be appreciated, especially if you arrange your folders or devices so they are easy to reach without wasting too much space. Thanks in advance for your detailed experiences and tips!
garudi
3 Feb 2024 12:39
Dilen schrieb:
A specific question for you: How much equipment do you want to fit into the cabinet? Just accessories or also, for example, a printer or scanner?
Thanks, Dilen, good point! I currently keep the printer and scanner separately and don’t want to lock them away in the Pax wardrobe because they emit heat and I access them frequently. The equipment inside the Pax will mainly consist of a docking station, charging stations, and a small router, as well as some chargers. Accessories like a mouse, pens, notepad, and external hard drives will also be stored there. A laptop is usually used on the desk, so having a compartment for quick storage would be helpful. The goal is to achieve better organization while maintaining quick access.
theo63
4 Feb 2024 08:11
One aspect that is often overlooked is the issue of ventilation for equipment inside the PAX unit. Even if your setup is relatively small, you should ensure adequate air circulation, especially around the docking station and router. Enclosed cabinets can cause heat buildup in these areas. My recommendation is to include drill holes or at least ventilation grilles on the sides or back panels near the equipment to avoid performance or lifespan issues. Additionally, I wonder: how important is quick visual access to your equipment in case of problems? In this case, a partially open door or at least a door with a viewing window might be worth considering.
Kinbu
4 Feb 2024 10:44
Hello garudi, in summary, I would recommend the following:
- Interior layout with adjustable shelves and at least one or two drawers for small items.
- A pull-out shelf for technical equipment, combined with cable grommets and cable clips to prevent movement or tangling.
- Install doors as planned, paying attention to material and ventilation. If dust protection is the priority, solid wood fronts are the better choice.
- Cable management: not just cable ties, but also flexible cable ducts or cable inlets to keep things organized.
- Space for binders preferably in the middle or lower sections, with fewer shelves to avoid dividing the space too much.
If you like, I can also share some tips on how to equip the PAX system with smart lighting elements – this makes it much easier to find things in low light and looks modern. By the way, what about the depth of your binders? Standard A4 binders or rather ultra-slim ones?
