I recently purchased several Malm dressers from IKEA and am now facing the challenge of securely and properly screwing them together. It is important to me that the connection is not only strong but also as hidden and durable as possible, especially considering that the furniture might be taken apart and reassembled during a possible move.
My questions are: Which screws or fasteners are best suited for optimally joining Malm furniture? Are there any special tips for preparing the material, such as pre-drilling or reinforcing with dowels? And how can I avoid compromising the furniture’s stability or appearance?
I would like to gather some experiences here, especially from people who have previously screwed together similar furniture and found a reliable solution. Thanks in advance!
Hello DULA44,
I find your questions very precise and important, especially since Malm furniture is often made from chipboard with a foil coating, which makes screwing somewhat challenging.
For screwing, I generally recommend pre-drilling an appropriate hole (about 2-3 mm smaller than the screw diameter) before inserting the screw. This helps prevent the material from cracking or splitting. Most connections on Malm dressers are already pre-assembled with dowels and elongated holes, but if you want to use your own screws, wood screws with a countersunk head work best.
For added stability, you can also use wooden dowels – for this, the holes must be drilled cleanly and flush, and wood glue might be necessary. This is a good way to join the bottom and side panels securely without any movement.
An important point is not to overtighten the screws – especially with chipboard, there is a risk that the screw will cut into the material and no longer hold properly.
If you frequently assemble and disassemble the furniture, a connector system with furniture fittings (e.g., cam locks) might be a better solution, as they are reusable multiple times.
I hope this helps you get started!
Hey DULA44, it’s great that you want to screw the Malm together properly! 🙂 I love Ikea furniture, but when it comes to stability, sometimes you need to reinforce it.
My recommendation: definitely use fine-thread screws, as they hold better in wood! Pre-drilling is essential, otherwise you risk splitting the panels – and believe me, that happens faster than you think!
A tip from me: add small wooden dowels as well; that gives extra strength and makes everything much stiffer. I’ve tried it myself, and my Malm dressers are rock solid, even though the original screws sometimes have some play.
Also, take it easy when tightening; if it feels too stiff, it’s usually better to loosen it slightly and try again. Don’t use too much force, or the panel will break! You’ve got this! 🙂
Hello DULA44,
I’ll add a casual tip: When screwing the Malm dressers together, don’t forget there are small tricks to preserve the appearance – for example, countersinking the screw heads and covering them with wooden plugs, which almost looks original.
That’s really good advice! I have even used wood glue together with the dowels, which makes the joint really solid.
Oh, and if you ever need to adjust one of the side panels, definitely put something soft like felt pads or a cloth under the furniture base to protect the boards while screwing. 🙂
You don’t want a beautiful white surface covered in scratches in the end...
LEMAN schrieb:
A tip from me: Use small wooden dowels; it adds extra strength
Thank you very much for the detailed answers!
That’s definitely a point I hadn’t fully considered before. I always thought the tighter the screw, the better it holds. Now I understand that overtightening can actually damage the material, especially with chipboard.
My question is: How tightly can you generally screw in without risking damage to the material? Is there a practical way to test this appropriately? Or is it better to use a torque wrench for this?
Also, what are your thoughts on using wood glue for reinforcement? I’m wondering if it makes sense with the common chipboard, which is not really tolerant to moisture.
Looking forward to your opinions!
Ianlau schrieb:
that you shouldn’t overtighten screws
Hello DULA44,
Regarding your question about tightening screws:
With particleboard, it can be tricky because too much pressure can cause it to crumble. As a general rule, tighten the screw until you feel resistance, then carefully turn it about a quarter turn more, but no further. Use a Phillips or Torx screwdriver with a good grip to avoid slipping.
If you want to tighten screws reliably and consistently, a torque wrench with a low setting is a very good idea; you can start at around 3–4 Nm. This allows you to gradually find the right level.
Wood glue can definitely help; it is usually the type used for photovoltaic panels, which becomes waterproof when dry. I recommend using only small amounts so that nothing oozes out of the joints, especially with foil coverings. Applying glue sparingly to the dowels or drill holes is not a problem.
A small test piece beforehand or an inconspicuous corner could certainly help to check how the material and glue interact.
DULA44 schrieb:
What do you think about using wood glue for reinforcement?
