Hello everyone, I have a specific question: What is the best way to protect my IKEA Malm furniture from moisture? Specifically, I’m interested in how to treat or care for the wood or surface so that it doesn’t swell or get damaged from humidity (for example, in bedrooms with fluctuating moisture levels). Are there any special protective products, coatings, or measures that you would recommend, without negatively affecting the appearance or functionality? I would appreciate it if anyone has experience or solid advice on this.
To prevent moisture damage to Malm furniture, which is usually made from particleboard with a melamine finish, it is crucial to protect the edges, as moisture can penetrate there. A transparent edge sealant or color-matched acrylic sealant can permanently seal the cut surfaces.
This is only partially true, as wax or oil barely penetrates melamine-coated furniture. It is much more important to avoid standing moisture and to ensure good air circulation.
I also recommend not placing the furniture directly in front of radiators, as rapid temperature changes can stress the material.
Alternatively, you can use special furniture sealants from specialty stores that are suitable for particleboard and impregnate the surfaces without altering their appearance.
liRaul49 schrieb:
A thin layer of furniture wax or oil can help.
The question arises to what extent additional protection is truly necessary when Malm furniture is already made with melamine-coated material, which is quite resistant to moisture by itself.
Absolutely correct, this is usually the weak point. But how effective are commonly available acrylic seals or coatings under regular use and humidity?
One could argue that the best precaution is optimized indoor climate control: maintaining stable humidity between 40-60% and controlled ventilation. This provides the best long-term protection for the furniture.
Another questionable measure is applying protective products designed for solid wood – this can cause undesired visual effects and problems on melamine surfaces.
Here, I recommend carefully checking IKEA’s material data and not simply applying sealants that may damage the material or make it look unattractive.
SUBEN60 schrieb:
to especially protect the edges, as moisture can penetrate there
