ᐅ How can I optimally place IKEA PLATSA furniture in rooms with sloped ceilings?
Created on: 4 Jun 2021 09:27
muleken
muleken
4 Jun 2021 09:27
I plan to use IKEA Platsa furniture in my attic room, but I find it challenging to position the modules effectively due to the sloping ceilings. My main question is: How can I optimally place IKEA Platsa furniture with sloped ceilings to make the most efficient use of the space, ensure the furniture is stable, and keep the cabinets or shelves practical to use? I am especially interested in whether anyone has experience combining different height modules and how best to adapt to the slanted walls during assembly, given the adjustable heights and numerous configuration options. Tips on securing the furniture and possible modifications are also very welcome, particularly to avoid unused space or a wobbly setup.
Israel62
4 Jun 2021 11:03
It’s best to use the lower PLATSA modules for the area under the sloped ceiling. You can adjust them directly to the wall, keeping the height consistent.
For the taller modules, choose free wall spaces without a slope. For stability, it helps to secure the furniture to the wall or to each other.
jeff65
5 Jun 2021 08:46
This is a very important point. Especially with sloped ceilings, uneven surfaces are common, so I recommend measuring the wall precisely before assembly and using tension straps or brackets for additional stability if needed.
It is also useful to install the shelves flexibly and to combine height modules cleverly to make the best use of the angled space. I have also had good results attaching small braces to interior edges when the modules have different height combinations.
Another tip: use the optional feet from PLATSA to compensate for minor floor unevenness.
V
Victor54
6 Jun 2021 22:11
muleken schrieb:
How can I optimally place IKEA PLATSA furniture against sloped ceilings to make the most efficient use of space, ensure the furniture is stable, and keep the cabinets or shelves practical to use?
This question is complex because it combines different aspects: space utilization, stability, and ergonomics. In my opinion, it is worth first creating a to-scale sketch of the room including the slope and marking the modules on it. You shouldn’t just see the modules as simple rectangular boxes, but rather take advantage of the flexibility of the individual components.
Why do I emphasize this? Because it is often overlooked that, for example, open shelves or very low cabinets can be arranged to form a transition and thus reduce wasted space. Adapting to the slope often means not just considering the overall line of the furniture, but maintaining the space through clever positioning and combining modules with different depths.
Regarding fastenings, you should consider not only horizontal and vertical brackets but also diagonal braces to prevent unstable constructions. One more thought: take access to doors or drawers into account. A narrow access can quickly limit functionality, even if everything looks fine visually.
