I am currently planning the layout of my apartment and want to use my Billy shelves in a way that fits the room size perfectly. I find it especially challenging to plan for small or oddly shaped rooms.
I am particularly interested in how to adjust the shelves both in width and height without making the room feel cramped or negatively affecting the sense of space. Modular expansion and placement are also important aspects for me.
Does anyone have experience with custom modifications, whether by cutting, combining different shelves, or clever arrangement? It would also be helpful to know how to maximize storage space while maintaining a pleasing visual effect.
I look forward to your tips or even practical examples! Thanks in advance.
Genevieve15 Mar 2022 20:43Interesting question, ottobu.
First, it is important to know the exact dimensions of the room precisely. Only then can you analyze how the standard sizes of the Billy shelves can be adapted. They come in various heights (approximately 40, 80, 106, 202 cm [16, 31, 42, 79 inches]) and widths (approximately 40 and 80 cm [16 and 31 inches]).
In my opinion, this is the key point: In smaller rooms, tall shelves can quickly become dominant, although this also depends on the ceiling height. In narrow rooms, shallower shelves combined together are usually better to create flexibility.
It should also be noted that Billy shelves are well suited for cutting to size, but special tools and carpentry skills are needed, for example, to reduce the height. The side panels can be cut, but the construction of the back panel sometimes makes it difficult to modify the carcass very flexibly.
Furthermore, using different colors or light-colored back panels is recommended to improve the perception of depth in the room.
In this context, I wonder: Do you have specific room dimensions, and what is your main focus for use? More books? Decoration? This could influence the decision.
ottobu schrieb:
how I can adjust the shelves both in width and height without them overwhelming the room or negatively affecting the sense of space
Hello ottobu,
I would like to take a more technical approach to this topic and offer you some step-by-step considerations to optimally adjust your Billy shelves to your room size.
1. Plan the measurements carefully: In addition to measuring the room length and height, also measure the available floor space, including allowances for doors, radiators, or windows.
2. Choose the shelf depth: While the standard depth is 28 cm (11 inches), sometimes the flexibility of shallower shelves (e.g., 20 cm (8 inches) depth) can be crucial to avoid overcrowding the space.
3. Height variation: Instead of using a few tall shelves, varying the heights (e.g., one at 202 cm (80 inches) next to an 80 cm (31 inches) shelf) can visually open up the room.
4. Combine widths: If space is tight in width, it’s worth combining different shelf widths. You can also place shelves side by side with varying widths to allow adjustments on site.
5. Adjustment by trimming: The side panels can be trimmed with a circular saw to make shelves slightly shorter. It is important to carefully finish the edges afterward and use solid back panels to maintain stability.
6. Modularity and expandability: Use additional elements like topper shelves or extra shelves to keep storage adaptable. This way, you can respond to changing needs.
7. Visual tricks: Light colors, open back panels, or integrated lighting help make the space appear larger.
Could you provide your room data (length, width, height) and the intended use for a more detailed analysis? It would also help to know whether you prefer shortened shelves or rather a continuous, tall shelf depth.
ottobu schrieb:
I’m particularly interested in how I can adjust the shelves both in width and in heightHello,
I would like to support the previous tips with some practical advice: If you want to shorten certain shelf parts, check the measurements carefully and especially make sure not to damage any load-bearing side panels. Billy shelves are usually assembled with dowels and screws, so it’s best to take them apart first when making modifications and then reassemble them.
Also, IKEA often offers matching tops or frames that you can use as add-ons to create a continuous shelving unit with varying heights. This adds structure to the room without making it feel too bulky.
If your room has an awkward layout, consider using shelves with less depth in tight areas to maintain enough space for movement.
PLOMA schrieb:
Modularity and expandability help keep storage adaptableI agree with that; inflexible solutions make it difficult to adjust later as needs change. Lighting near shelves also enhances the sense of space.
If you like, I can give you some concrete examples of how this could look.
