ᐅ How can I install BILLY shelves under sloped ceilings?
Created on: 15 Jun 2022 18:23
mauefecan
mauefecan
15 Jun 2022 18:23
Hello everyone, I am planning to install a few Billy bookshelves from IKEA in my room under the sloped ceiling. My specific question is: How can I securely and stably mount these shelves on a slanted wall so that they don’t wobble or become unstable later on? The slope of the ceiling is about 45 degrees, not vertical, and standard wall brackets are not ideal for me because the standard Billy shelves are designed for flat walls. Are there any special mounting tips or accessories that would allow me to adapt the shelves to fit perfectly and securely? Thanks for your advice!
Fitigu
15 Jun 2022 19:07
Hello mauefecan, basically there are two main points when mounting BILLY shelves under sloped ceilings: first, secure anchoring in the wall, and second, adjusting the support surface to the slope. For mounting, I recommend special angled brackets that you can cut or bend to fit the angle – often you have to customize these yourself. Alternatively, some hardware stores offer flexible shelf brackets with joints. It is important to accurately measure the roof pitch with a protractor before installation, then either make a custom wooden wedge that fits between the shelf and the slope, or adjust metal brackets so that the shelf is held perpendicular to the slope.
Another option is to attach a sturdy back panel under the slope – such as a wooden board precisely cut to fit the incline – and then screw the shelf to that. This gives you a flat mounting surface. This increases stability and makes installation easier. Be sure to check the load-bearing capacity of the wall behind the slope (e.g., roof battens, masonry) so the screws have a secure hold.
Timofa
15 Jun 2022 19:48
Hey mauefecan, I worked on a similar project a while ago. Let’s just say: BILLY shelves are quite sturdy, but it gets tricky under a sloped ceiling. My trick was not to fix the back panel of the shelf directly to the sloped wall with standard brackets, but to attach it to a custom-made wooden strip that I cut to the exact size. The strip then keeps the shelf perfectly vertical, and the screws go into a solid substructure – this way nothing wobbles, and the shelf stands rock solid.
It sounds like extra work, but it’s worth it, especially if you plan to load the shelf heavily 🙂 Also, make sure the drill holes on the sloped wall are not too close to the edge, as they won’t hold as well.
Oh, and if you want – with such a strip, you can also adjust the shelf depth and better utilize the space under the slope. Good luck!
GALEO4
16 Jun 2022 08:32
Fitigu schrieb:
Another option is to install a sturdy back panel under the slope – for example, a wooden board precisely cut to fit the angle.
Sure, this approach looks neat, but honestly: who wants to screw a bulky wooden board under the slope so it ends up looking like something from a hardware store? In my opinion, it’s much better to simply cut the shelves to fit perfectly into the niche. Thanks to side cutters and a hand saw, it’s quite doable.
Or how about freestanding solutions instead of rigidly fixing everything? Slopes often reduce storage space, so why forcefully screw the shelf in place? I’m not a fan of hanging BILLY shelves on slanted walls because they aren’t designed for that. It becomes problematic once the wall doesn’t allow for proper support.
For those who still want to do it: just cut a sturdy wooden board as a base or back panel, place the shelf on it, stabilize with brackets – done.
mauefecan
16 Jun 2022 09:14
GALEO4 schrieb:
Who wants to screw a bulky wooden board under a sloped ceiling
I understand the point about appearance, but for me, functionality and especially safety are what matter. I don’t want the shelf to fall down or be unstable at some point, especially since I plan to store heavy books there.
Timofa schrieb:
not attaching the back panel of the shelf directly to the sloped wall with standard brackets but to a self-built wooden batten
That sounds interesting – how did you fix the batten in place, and how did you make sure it is really stable? Are there any tips I should keep in mind when installing it?
It would be great if someone could share technical details on the mounting process as well as the most suitable screws and wall plugs.
KUDAISY
16 Jun 2022 11:52
Hello mauefecan, here are a few practical tips regarding your issue:
1. Preparation: You should first precisely measure the roof slope (angle, depth). A protractor or digital inclinometer is very helpful for this.
2. Wooden batten for mounting: Timofas’ solution is practical. It is best to use a sturdy batten (e.g., planed spruce wood, 40x60 mm (1.6x2.4 inches)). Cut this batten so that it fits exactly on the slope and can be securely screwed to the straight wall.
3. Screws and anchors: Use heavy-duty anchors (e.g., Fischer DUOPOWER) for solid walls or appropriate cavity anchors for drywall. Prefer countersunk screws with a length of at least 6-8 cm (2.4-3.1 inches) to ensure they anchor deeply into the masonry.
4. Shelf fixing: The shelf is then attached with brackets or directly screwed onto the batten. Make sure not to place screws too close to the edge of the shelf to avoid splitting.
5. Safety: Check the wall’s load-bearing capacity, if necessary using a stud finder to locate timber or metal studs.
Common mistakes include inaccurate angle measurements, screws that are too short, and lacking a stable substructure. A precisely fitting batten is the backbone of the entire construction.
If you like, I can describe a sketch with measurements and fixing points for you.
