Hello everyone, I am planning to modify some IKEA MALM furniture to make it more child-friendly, especially for a younger child. My question is: how can I adapt MALM furniture to be safe for children without compromising its stability, and which modifications provide the best protection against injuries or accidental pinching? I am particularly interested in practical solutions that can be done with simple tools and without expensive specialized equipment. Maybe you have experience with padding, rounding edges, or reinforced fastenings? Also, any advice on which parts are better left unmodified would be very helpful. Thanks in advance for your tips!
Leonardteo27 Jun 2020 16:12Basically, the stability of the joints is crucial when it comes to MALM furniture, especially if you want to modify it for children.
If I were you, I would start by protecting the corners and edges with foam or silicone profiles. These are easy to attach and help prevent children from painful bumps. Additionally, I recommend fitting doors and drawers with soft-close hinges or self-adhesive soft-close pads to avoid finger injuries.
Important: When modifying the furniture, the screw connections should be checked regularly, as they can loosen faster due to frequent use by children.
Tolis schrieb:
How can I make MALM furniture child-friendly without compromising stability?
Oh yes, MALM furniture looks nice, but it’s not always completely child-safe – I’m just thinking of those sharp edges and sensitive little heads 😉
I have even fitted some drawers with childproof locks to prevent little explorers from accidentally pulling everything out. A bit of DIY, a bit of child safety – and suddenly the furniture becomes a friend for the kids’ room! 🙂
Leonardteo schrieb:Exactly! These protective strips are super easy to use, don’t look ugly, and save many a head from a bump. I have also found that adding extra handles to the drawers, which are easier to grip, works well.
Protect corners and edges with foam or silicone profiles
I believe it is important not only to rely on the usual padding and cushioning but also to critically evaluate which modifications truly make sense.
For example, is it possible to completely remove drawers or doors and instead install flip-up elements? This would completely prevent pinching but naturally raises questions about practicality for everyday use. Additionally, it is important to consider whether changes to the load-bearing points affect the furniture’s structural integrity. A sturdy MALM frame is designed to withstand specific loads and movements – DIY modifications without careful planning carry risks.
Have you had any experience with alternative door systems on MALM? That would be an interesting addition to the discussion.
Tolis schrieb:
Which modifications offer the best protection against injuries or unwanted pinching?
