ᐅ How can I modify Malm furniture myself?
Created on: 21 Oct 2015 14:07
Goson51
Goson51
21 Oct 2015 14:07
I am planning to modify a piece of furniture from the IKEA Malm series, but I don’t yet have a clear idea of the best approach. I am particularly interested in how to maintain or even improve the stability and functionality of the furniture.
I am also curious about which tools and materials are best suited for this project, as I want to minimize any damage to the furniture. Are there established techniques or useful tips, especially for shortening drawers or adding extra compartments?
I would appreciate concrete advice and possible methods, as I want to customize the furniture to fit my specific space. Thanks in advance!
alvalo
21 Oct 2015 14:42
Hello Goson51,
Basically, Malm furniture can be somewhat sensitive to modifications due to the material-specific panel construction (chipboard with melamine coating), but with proper care, it can be worked on quite well.
An important tip: plan your cuts and drillings very precisely to avoid compromising the load-bearing capacity as much as possible. Clean circular saw blades or a fine-toothed handsaw are suitable for cutting. For drawers, for example, you can remove the back panel and adjust it separately to change the internal height.
Tools I recommend include a cordless drill, a fine jigsaw, a detail sander or sandpaper for the edges, and a protractor for precise marking. Also, make sure to always pre-drill with a thinner drill bit before the actual holes to prevent splintering.
If you need more details, I’m happy to help!
PIDAN
21 Oct 2015 15:05
I’ll add some technical details. It’s important to check how the furniture is assembled before starting any modifications: usually, dowels, cam locks, or screws are used. Disassembling individual parts should be done carefully with the right tools (e.g., a knock-out punch) to avoid any deformation.
The material is often 16 mm (0.63 inches) thick, so keep that in mind when cutting. For additional compartments, it’s best to use laminated solid wood panels or plywood for better stability, as the particleboard in Malm-style furniture can easily split.
Also, if you want to shorten drawers, you can unscrew the side panels and reassemble them using suitable additional runners. Otherwise, the original drawer will lose its guidance and stability.
Be cautious with painted surfaces; if you do any touch-ups, the finish can be more easily damaged.
fidasi
21 Oct 2015 17:18
Hello Goson51,
I assume you mean a classic Malm dresser model. When remodeling, it’s helpful to create a work plan before you start using your tools.
1. Measure your furniture exactly (width, depth, height, thickness of the panels).
2. Decide which parts you want to modify: fronts, side panels, drawers.
3. Consider how the added weight from new parts might affect the structure.
For the remodeling process itself, I recommend the following steps:
- Shorten drawers: Remove the back panel, cut it to the desired height, and reassemble it with strong glue joints or small brackets.
- Add compartments: Use wooden strips (at least 18mm (0.7 inches)) for the supports and attach them with biscuits (Lamello) or dowels; this increases durability compared to simple screws.
- Reinforce screw holes: For critical points, it’s advisable to insert an overlapping screw through the screw head from the open side; this stabilizes the joint.
- Surface: Use sanding and special spray paints designed for melamine if color adjustment is needed.
One more thing: Could you specify which exact modifications you have in mind? That helps to give more precise advice.
Goson51
21 Oct 2015 17:47
fidasi schrieb:
One more important thing: What exact modifications are you considering? This will help to give more precise advice.
Thank you for the detailed response!
Regarding the planned adjustments: I want to make the dresser overall a bit narrower because it will be placed against a narrow wall. This means I would need to reduce the width of the side panels by about 10 cm (4 inches). At the same time, I would like to install an insert with smaller compartments (for example, for documents or small items), which would reduce the existing drawer space.
Another idea is to reinforce the top panel, possibly with an additional layer or a different material thickness, so that I can later place heavier objects on it.
The main challenge I see is to maintain the original appearance as closely as possible while ensuring stability. What approach would you recommend here?
RUBEN54
21 Oct 2015 18:21
Hello Goson51,
Regarding the topic "shortening the side panels by 10 cm (4 inches)," my tip is: If you can completely disassemble the dresser, that is the best starting point. Begin by carefully detaching the side panels. The Malm carcass is connected with Minifix fittings and wooden dowels – these must be removed very carefully during disassembly to avoid breaking them.
For shortening, I recommend using a circular saw with a fine-tooth blade to ensure splinter-free cuts on the melamine surface. Afterwards, sand the cut edge thoroughly and seal it with a suitable edge banding (melamine or ABS) to prevent moisture damage.
For installing inserts for smaller compartments: Measure the interior space precisely and make cuts from 12-15 mm (0.5-0.6 inch) thick MDF or plywood panels. Glue the parts together and secure them with small screws or brackets that are barely visible from the inside.
You can reinforce the surface by adding an extra MDF panel (at least 18 mm (0.7 inch) thick), which you can attach invisibly with staples or glue. This preserves the appearance while increasing load capacity.
Summary:
- Fully disassemble the furniture
- Take exact measurements
- Shorten side panels with a fine-tooth saw blade
- Seal edges carefully
- Use sturdy engineered wood for inserts
- Use a top panel for reinforcement
However, if you don’t have much experience with woodworking yet, I recommend a dry run with a similar piece of wood before you disassemble the Malm furniture.
