ᐅ How can I modify Ikea Platsa furniture to fit sloped ceilings?
Created on: 7 May 2024 08:34
lini53
I am planning to use my Ikea Platsa furniture in a room with a sloped ceiling, but I’m facing the common issue that these cabinets are usually not designed for angled walls. My goal is to modify the furniture so that it fits perfectly under the slope without losing storage space or having to fully customize it.
Does anyone have experience or tips on how to best adapt the Platsa units to sloped ceilings? I’m especially thinking about the following points:
- Material processing (e.g., cutting or sawing the back panels or sides)
- Stability and safety after modifications
- Combining with additional elements or top pieces
- Ideas for achieving neat, precise finishes along the angle
I appreciate any advice, including recommendations on tools or complementary DIY solutions. Thanks in advance!
blapau
9 May 2024 09:08
As an additional tip: When adapting Platsa furniture to sloping ceilings, it is important to pay attention to the load capacity of the connection elements used.
- Screws for wood should be extra long to ensure a secure hold.
- Also use metal angle brackets, which you fix in place with a drill.
- If you shorten or remove the back panel, reinforce the sides further, as the back panel often provides stability.
- Alternatively, you can combine a back panel made of thin plywood with an angle profile, which offers high stability while using less material.
This way, your furniture will remain secure even when subjected to unusual loads caused by the sloping ceiling.
mauka
9 May 2024 12:45
juMira46 schrieb:
Also an idea: I adapted a Platsa dresser to fit a sloped ceiling and added flexible trims to the fronts along the slope. They create a smooth transition and prevent it from looking like a quick fix.
That’s such a great tip! I love when furniture is customized not just for function but also with a little design twist. For the trims, you can also use rubber profiles, which add a nice softness to the touch—very useful if you often brush past the edge.
And for those who enjoy DIY projects: with some sandpaper and a heat gun, you can nicely round off the edges of the cut parts to avoid splintering or a frayed appearance.
kieran
10 May 2024 08:19
blapau schrieb:
- Screws used in wood should be extra long to ensure a secure hold.
Additionally: It is important to pre-drill holes before driving in screws, especially for chipboard, to prevent cracking.
- Furthermore, for flat-pack furniture for sloped ceilings, I recommend securing the screw joints with wood glue after assembly.
- When using metal brackets, they should have a rust protection coating to ensure long-term durability.
These detailed tips significantly increase the lifespan.
