ᐅ How can I modify Ikea Platsa furniture to fit sloped ceilings?
Created on: 7 May 2024 08:34
lini53Hello everyone,
I am planning to use my Ikea Platsa furniture in a room with a sloped ceiling, but I’m facing the common issue that these cabinets are usually not designed for angled walls. My goal is to modify the furniture so that it fits perfectly under the slope without losing storage space or having to fully customize it.
Does anyone have experience or tips on how to best adapt the Platsa units to sloped ceilings? I’m especially thinking about the following points:
- Material processing (e.g., cutting or sawing the back panels or sides)
- Stability and safety after modifications
- Combining with additional elements or top pieces
- Ideas for achieving neat, precise finishes along the angle
I appreciate any advice, including recommendations on tools or complementary DIY solutions. Thanks in advance!
It is important to take precise measurements of the slope before the renovation and transfer them onto an accurate template. This allows you to cut the Platsa elements precisely.
- Use a jigsaw with a fine blade to work on the carcass cleanly.
- Cross-sections can be sealed with silicone or acrylic to achieve a flush joint.
- Reinforce cut edges with metal brackets and wood glue for strength.
- If necessary, build small spacers to compensate for unevenness.
This ensures a durable result.
Franck schrieb:
With Platsa, it usually helps to cut the side panels at an angle matching the roof slope.That's true, it was the same for me! At first, I was unsure about how to approach it, but using a template made it surprisingly easy. I was a bit worried that the furniture might become unstable, but adding brackets gave it stability. Using small clamps also helped me keep everything under control.
I completely understand feeling uncertain when remodeling, especially if you don’t want to damage the furniture. But it’s definitely worth it, as you can gain a lot of storage space despite the sloping roof.
Hey, I really liked kieran’s tip about using small spacer pieces! It’s such a clever hack when you need some room at an angled wall to accommodate unevenness – basically like little cushions for your furniture. 😄
Another idea: I customized a Platsa dresser for an angled wall and added flexible strips to the fronts at the slope, which create a smooth transition and prevent it from looking like a makeshift fix.
You really have to get creative— it can be a lot of fun when you embrace it!
lini53 schrieb:
Does anyone have experience or tips on the best way to adapt Platsa units to sloped ceilings?One more point: Platsa doors can often be reversed easily, so they open well even on a slope. Simply reposition the hinges or try alternative door solutions like sliding doors.
