ᐅ How can I modify the IKEA Brimnes unit to create additional storage in the living room?
Created on: 30 May 2020 13:17
ruzar2Hello everyone, I am considering modifying my IKEA Brimnes furniture in the living room to make better use of the existing storage space. Specifically, I am interested in how to modify the individual components, such as drawers, doors, and possibly the back panel, to create more and especially more organized storage capacity. This could include structural changes like adding shelving parts or repurposing elements for specific items (such as cables, books, or decorations). Has anyone had experience or tips on how to effectively alter the Brimnes system without compromising stability or appearance too much? I am looking for practical suggestions, such as alternative installation options or useful additions. Thanks in advance!
For an effective modification of the IKEA Brimnes furniture system to increase storage space in the living room, I recommend the following approaches:
- Remove the back panel to integrate shelving units or cable channels from behind, creating additional lateral storage space.
- Replace the standard shelves with custom-cut shelves, for example, with reduced height for DVDs or small items.
- Use the inside of the drawers to attach organizers or small hooks for better organization of small parts.
- Add built-in LED lighting inside to make the interior more visible.
All these measures are reversible and have little impact on the stability of the furniture but should be carried out carefully and preferably with the appropriate tools. It is important not to damage the original IKEA fastening system, so the furniture can be restored to its original condition if needed.
JAMESONB4130 May 2020 16:22Take a look, you can equip the inside of the doors with shelves or small boxes. This significantly increases the space for small items.
RENMA schrieb:
Removing the back panel to integrate shelving units or cable ducts from behind, which creates additional lateral storage space.That’s interesting, but do you have any insights regarding stability? Without the back panel, the furniture loses a significant amount of rigidity, doesn’t it? It would be helpful to know if there are specific reinforcements needed or other solutions to keep the furniture stable when the back panel is completely removed.
Also, I wonder if such a major modification is more sustainable, or if better storage solutions can be achieved by combining additional furniture pieces, for example. I would like to understand the limits of this kind of modification.
One way to improve the Brimnes model without compromising stability is to install additional shelves made of wood or plastic that are better suited to the items being stored.
- For the drawers, you can use insert boxes or dividers to organize the compartments more clearly.
- I would only partially remove the back panel to maintain enough stability. Additionally, I recommend reinforcing the frame with brackets or metal profiles if the back panel is modified.
- For cable management inside the furniture piece, cable ducts can be discreetly installed on the inside.
This allows for more functionality while preserving the design and sufficient stability.
Victor54 schrieb:
It would be helpful to know if any special reinforcements are needed or other solutions to keep the furniture stable when the back panel is completely removed.Thanks for the tip, the point about stability is really important. My exact goal is to open up the back panel for expansion, but at the same time, the Brimnes must not lose its strength, as it is used for storing books and electronics.
Are there proven methods or specific materials (e.g., metal brackets, battens) that can be added afterward to compensate for the missing back panel? Or would it be better to keep part of the back panel in place and prioritize other modifications instead?
One more question: What are your experiences with clamp and slot systems for attaching shelves or organizers? Do they hold well, or is it better to use screws?
