ᐅ How can I modify Ikea Besta units for use in a child's bedroom?
Created on: 5 Dec 2023 09:37
badeo70
badeo70
5 Dec 2023 09:37
I am currently considering how to modify my Ikea Besta shelving system to make it optimal and safe for use in a child's room. The goal is to design the furniture piece to be child-friendly, sturdy, and as flexible as possible. I am particularly interested in what adjustments you make to, for example, soften sharp edges, optimize storage for toys, or convert the system into a multifunctional solution—such as adding a changing top or a bench.
It is especially important for me to get detailed and practical advice on which materials are suitable for modifications, how to improve stability, and which installation methods are recommended.
Has anyone here had experience and can offer tips for a safe and durable modification of the Ikea Besta for a child's room? I look forward to your responses!
KIN42
5 Dec 2023 11:15
Hello badeo70,
your question addresses the key issues very well, especially the aspects of stability and child safety, which are essential. Based on my own experience, I can offer the following recommendations:
- Always cover edges and corners with protective soft edging. EVA foam profiles, which can be easily cut and attached, are especially suitable for Besta units.
- To increase stability: reinforce the back panel and firmly secure the furniture to the wall – IKEA offers appropriate safety kits, which are very important when children are around.
- For flexibility: shelves can be easily removed or rearranged to create custom compartment sizes.
- If you want to integrate a bench seat, I recommend screwing a sturdy wooden board onto the Besta carcasses and topping it with a padded cushion.
Material quality and careful assembly are important factors. If the piece of furniture is used as a changing table, the changing top should be securely fixed and made of moisture-resistant material.
I hope this helps with your project.
U
usbla
5 Dec 2023 13:02
in addition to KIN42’s comments, I would like to add a few technical aspects that I consider important in a structured way:
- Load capacity: Ikea Besta units are designed for standard household use, so they are not intended for excessive loads. If you want to integrate additional elements (e.g., a bench seat, changing table attachment), you should check whether the existing joints can support the weight or if additional reinforcements (e.g., metal brackets) are necessary.
- Child safety: Besides the edge protectors already mentioned, I recommend magnetic catches or child safety locks for doors and drawers to prevent unintended opening.
- Surface modification: Ikea Besta is usually coated with melamine resin, which is scratch-resistant but not very soft or child-friendly. An optional solution would be to cover the fronts with washable films or child-friendly chalkboard films to enhance the furniture’s appearance and durability.
- Assembly instructions: Always ensure secure, tight connections during assembly. Regularly check all screws and fittings for tightness after modifications.
Following these steps helps avoid future safety risks and ensures a long-lasting solution.
Nathanaelk
6 Dec 2023 08:46
Hello badeo70 and everyone interested,
I would like to go into more detail regarding renovation options, especially concerning safety and functionality. The Besta system is excellent due to its modular design, but it can quickly reach its limits in terms of mechanical loads when adding elements such as seating surfaces or changing table attachments.
An effective way to improve stability is to reinforce the base legs or add additional support blocks to the sides of the cabinet, as the original legs are only secure on level floors. I also recommend not only fixing the back panel but securing it with additional angle brackets attached to both the wall and the cabinet to prevent lateral movement.
As for child safety, please use only certified edge protectors, since even small sharp edges can be dangerous. For removable parts: drawers should have soft-close damping systems to avoid the risk of pinching small fingers.
If you plan to extend the Besta as a storage system with a seating area or changing table, it is advisable to use plywood panels as a base whenever possible, as they are significantly more durable and load-bearing than particleboard. The material can be safely sealed with child-friendly paint or coatings.
Finally, a small but important tip: check what kind of wall you have. For drywall, special anchors are required, otherwise the furniture may tip over.
If you like, I can send you a step-by-step guide for assembling and upgrading the Besta.
nojaus
7 Dec 2023 14:30
Nathanaelk schrieb:
If you like, I can gladly send you a step-by-step guide for assembling and upgrading the Besta.
That would definitely be a great help! I always appreciate when everyday practicality is considered in furniture modifications, especially when children are involved.
I once had a similar project with another IKEA system and understand how important it is for everything to be truly safe and sturdy – you sometimes underestimate how much kids pull and tug on furniture.
Maybe it would also be useful to share experiences here on which storage solutions work best for quickly putting away toys while keeping everything tidy? Open shelves or bins don’t always work well with very young children.
Thanks to everyone who has contributed so far – the tips on edge protection and securing the units have already given me a lot of useful input!
