ᐅ How can I modify and protect IKEA Metod countertops after installation?
Created on: 1 Apr 2022 08:36
pabalen
Hello everyone, some time ago I purchased an IKEA Metod kitchen and am now working on refinishing and protecting the countertops afterwards. My specific question is: What options, materials, or methods are available to enhance the typical white or wood-colored IKEA Metod countertop to make it more resistant to scratches, moisture, and heat?
I especially want to avoid water marks on the surface and am also looking for advice on whether the edges should be treated separately or if applying a suitable varnish or oil over the entire surface is sufficient. Additionally, I am interested in how time-consuming or complex such refinishing is, as I would like to achieve a good balance between effort and protection.
Does anyone have experience with recommended products or techniques? I look forward to your insights and tips!
Kolepau
1 Apr 2022 12:10
Top thread! I treated my Metod board with linseed oil, which gave it a really natural look. 🌿 For better durability, I then applied beeswax.
The whole process requires some patience due to drying times, but the result is worth it.
And yes, never neglect the edges! Otherwise, moisture can quickly get in and cause problems.
TEOZAR
2 Apr 2022 08:37
Hello pabalen, I want to answer your question honestly, as many people struggle with the aftercare of IKEA Metod countertops.
Basically, melamine or coated panels are not designed to be heavily worked on afterward. There is always a risk of damaging the protective layer. The safest way to increase durability is to apply a thin layer of clear furniture lacquer, especially on the edges, which are the most vulnerable.
I recommend the following procedure:
- Clean the panel carefully
- Lightly sand (maximum 150 grit)
- Remove dust
- Apply two to three thin coats of clear lacquer (using a brush or a roller designed for smooth surfaces)
- Allow each coat to dry thoroughly before applying the next
This will provide better protection against moisture. Thermal conductivity cannot really be improved this way, so coasters are essential.
If you’re unsure, test first on an inconspicuous area.
JORGERON
2 Apr 2022 09:05
Clear lacquer or hard wax oil are the two best options. Edges are especially important, so always seal them. Avoid experimenting with finishes that are not suitable for countertops.
Will44
2 Apr 2022 10:41
Victor54 schrieb:
That sounds reasonable at first, but I doubt that hardwax oil really provides long-lasting heat protection.
That’s true, Victor54, hardwax oil doesn’t make the surface heat-resistant—that’s never been my claim 😅. It mainly reduces water absorption and protects against minor scratches.
TEOZAR schrieb:
But thermal conductivity can hardly be improved with it, so coasters are essential.
I completely agree! Always use coasters, and the surface will last much longer.
praWarre69
2 Apr 2022 11:19
I’ll add a quick note: When working with 2-component clear coat, it’s better to apply very thin layers and sand well between each coat. This will make the surface truly durable.
The effort is worthwhile for those who use the kitchen heavily and need strong resistance. For occasional use, hardwax oil is usually sufficient.
