ᐅ How can I make the doors of an Ikea PAX wardrobe lockable?
Created on: 6 Sep 2022 14:07
pesimi
pesimi
6 Sep 2022 14:07
Some time ago, I bought an Ikea PAX system for my bedroom and I’m very satisfied with the wardrobe’s flexibility. However, I would like to make the doors lockable because I also store sensitive documents and small valuables inside.
Since PAX systems are generally not equipped with locks or latches from Ikea, I’m looking for practical ways to securely lock the doors.
It is important to me that the solution matches the furniture aesthetically, is easy to install, and can be implemented without causing significant damage to the cabinet or the doors.
Does anyone have good tips or maybe even accessories specifically designed for PAX doors? Recommendations for retrofit locks that can be installed with minimal effort are also very welcome.
Thanks in advance for your replies!
chenValeri
6 Sep 2022 14:35
the easiest option is clamp or snap locks that you attach directly to the inside of the door. Alternatively, there are magnetic locks that can be opened with a key and have no visible screws on the front. The only important thing is that the door thickness matches the lock.
Nakar33
6 Sep 2022 15:02
Hello pesimi,
I understand that you want to lock your valuables inside your PAX system. Basically, there are several ways to make PAX doors lockable, but the approach depends heavily on the type of doors you have (swing or sliding) and whether the doors have frames or not.
With sliding doors, it gets a bit more complicated because traditional mortise locks often don't fit. In these cases, magnetic locks or special PAX sliding lock kits, which Ikea sometimes supplies themselves or are available from third-party providers, are recommended.
For swing doors, small mortise locks that can be installed inside the door are recommended. However, this involves drilling, so you need to be careful not to damage the door. An easier alternative is to use furniture bolts with a lock, which are usually mounted inside with screws that can be easily removed later.
It is also important to measure the door thickness correctly and check the position where you want to install the lock—for example, at the top or bottom of the door, depending on how the wardrobe is constructed.
Magnetic solutions have the advantage of being almost invisible and easy to open with the appropriate key if you care about aesthetics.
What exactly are your doors like (material, door type)? This would help give a more precise answer.
Layla
6 Sep 2022 16:44
Hello pesimi,
I completely understand wanting to secure your belongings, especially with furniture that doesn’t come with built-in locks. I’m in a similar situation myself and was sometimes unsure how much effort is reasonable to make everything secure.
What helped me was first getting a clear idea of my own requirements: How much security do I actually need? Will multiple people be using it? Would a simple childproof lock suffice, or do you really need a lock to prevent unauthorized access?
Maybe this is something worth considering for you as well – I find that reflecting on these questions makes it easier to assess which products are the right fit.
What about you — are you looking more for preventive protection, or do you really need strong security?
pesimi
7 Sep 2022 09:12
Nakar33 schrieb:
What exactly are your doors like (material, type of door)? That would help clarify the answer.
Good question! My doors are swinging doors made of coated chipboard with a metal frame. The doors are about 18mm (0.7 inches) thick. The surface is smooth white, and the material on the inside is the same.
Layla schrieb:
What about you – is it more of a precautionary protection or do you really need strong security?
More of a medium level of security. I want to make sure that strangers or children cannot just open the doors easily. Forced entry or heavy-duty burglary protection is not really necessary for me, but a real lock with a key should definitely be installed to prevent unauthorized access.
chenValeri schrieb:
The important thing is that the door thickness matches the lock.
Noted, thanks for that!
Domau0
7 Sep 2022 11:29
Hello Pesimi,
based on your specifications for swing doors with a thickness of 18 mm (0.7 inches), I recommend the following approach:
- Mortise locks for hinged doors designed for wooden doors starting at 16 mm (0.6 inches) thickness can usually be installed easily. You will need to cut or rout a rectangular cavity in the door to fit the lock.
- Be sure to use a sufficiently sized lock case to ensure the latch is held firmly in place.
- Installing an escutcheon plate visually secures the lock and protects the key mechanism.
- If you want a visually harmonious look, choosing a white lock will at least match the door’s color.
Make sure to position the lock so that the strike plate mounted on the frame lines up properly.
If you don’t have a saw table or router, this can be challenging—consider looking for an installation service or friends who have the appropriate tools.
If you prefer to avoid drilling or routing, you can also use clamp-on or surface-mounted locks that can be fitted from the inside.
Would you like me to provide specific product recommendations?
