ᐅ How can I make MALM furniture scratch-resistant?
Created on: 22 Aug 2021 19:37
mauflo
mauflo
22 Aug 2021 19:37
Hello everyone, I recently bought a Malm bed and would like to protect it as best as possible from scratches. Since it is often made of chipboard with a foil surface, I’m unsure how to make it scratch-resistant without affecting its appearance or functionality. Does anyone have experience with methods or products that work well to protect Malm furniture from everyday scratches caused by clothing, jewelry, or objects? Information on long-term solutions that are not too expensive or complicated would also be very helpful. Thanks in advance for your tips!
Surela
22 Aug 2021 21:52
Hello mauflo,
First of all, it’s good that you are addressing this topic in detail, because MALM furniture typically has a melamine-coated surface, which is relatively durable but does not have a solid wood structure with natural scratch resistance.
To answer your question specifically: the best way to make the surface scratch-resistant is indeed to apply an additional protective layer. The following steps are particularly recommended:
1. Cleaning: Before applying anything, the surface should be clean and free of grease. It’s best to remove dust and grease residues with a mild all-purpose cleaner or a light alcohol-based cleaner.
2. Sealing: For this, you can use clear furniture waxes or special protective coatings for plastic surfaces. It is important that the products are suitable for coated particleboard. Clear spray varnishes based on polyurethane are often very durable, but should be applied in thin layers multiple times.
3. Alternative protective films: For areas subject to heavier use, there are also self-adhesive protective films that are transparent and can be removed without residue. However, these do not fit aesthetically with every piece of furniture.
4. Maintenance products: Occasionally treating the surface with furniture care products containing waxes or polymers extends the protection and makes minor scratches less visible.
One question for you: Is your MALM furniture heavily used in the bedroom (e.g., as a bed), or do you plan to use it more as a desk or dresser? Depending on the usage, we could offer more specific advice, since the wear on a bed is different from that on a desk.
A small caution: Some clear varnishes can turn whitish and matte after application if they are too thick or dry too quickly—so patience and careful work are essential.
I hope this helps you so far!
Tommy38
23 Aug 2021 09:11
Surela schrieb:
One more question for you: Is your MALM furniture piece in the bedroom heavily used (e.g., as a bed), or do you plan to use it more as a desk or dresser?
Hello mauflo,
I would like to join Surela and add a few points. If it is actually the MALM bed, the lying surfaces are mostly protected by the mattress and cover, but the frame and edges are more prone to scratches.
I recommend protecting the edges with narrow felt pads or silicone edge protectors, which are available especially at furniture or hardware stores. They help cushion impacts and rubbing.
Additionally, you can place simple coasters under items that stand or lie on the furniture.
Using a clear lacquer with surface sealing in the bedroom might be somewhat risky because it is not breathable, which can affect moisture levels, especially with furniture made from wood-based panels.
If you like, I can also give you recommendations for specific products that I have used myself and found reliable.
Best regards!
BOSULE
24 Aug 2021 07:28
Surela schrieb:
The best way to make the surface scratch-resistant is actually to apply an additional protective layer.
A very good point! However, I would like to add that, with most MALM furniture, the melamine resin-coated surface itself already provides a fairly durable plastic layer that offers high scratch resistance. Applying paint or wax can improve this property, but it should be done with caution, as it might alter the appearance or cause adhesion issues in the worst case.
So here is my advice:
- Instead, rely on preventive protective measures such as felt pads under chairs or other furniture that comes into contact with surfaces.
- Avoid placing hard or sharp objects directly on the surface and ensure regular maintenance using products specifically designed for plastic surfaces.
- If you still want to apply a sealant, test it first in an inconspicuous area to avoid color or gloss differences.
This way, you can achieve a good balance between protection and preserving the original design.
I hope this gives you clear guidance.
