ᐅ How can I reinforce Malm furniture to make it more stable?
Created on: 15 Jun 2016 07:43
Jaongi
Jaongi
15 Jun 2016 07:43
I am considering how to make my IKEA Malm dressers more stable. I understand that Malm furniture is designed as affordable, lightweight pieces, where stability is somewhat limited due to their lightweight construction. Especially with frequent use, heavier loads, or wider models, you can sometimes notice slight wobbling or even warping.
So my specific question is: What targeted measures or reinforcements can be applied to a Malm dresser to improve its stability? I am thinking of additional joints, reinforcements at critical points, possibly replacing individual components, or using stronger screws. Practical tips on which areas are particularly vulnerable and how to better approach them would also be interesting.
Has anyone had experience with such modifications or recommendations for better sturdiness without changing the overall character of the furniture?
Merlin
15 Jun 2016 09:12
The most important thing is to reinforce the connections at the corners with additional angle brackets or metal braces. Gluing the joints along with the screws also significantly increases stability.
Laluri
15 Jun 2016 11:26
Hello, I find that the back panel of the Malm series is often a weak point.
Merlin schrieb:
The most important thing is to reinforce the joints at the corners with additional angle brackets or metal corner braces.
I can only agree with that. Additionally, I would recommend fastening the back panel with stronger screws and, if necessary, reinforcing it from the inside with a second plywood sheet.
Attaching a solid wood base plate to the underside can also make the entire structure significantly more stable, especially if the chest of drawers is placed on uneven floors.
Jaongi
15 Jun 2016 13:45
Thanks for the tips so far!
Laluri schrieb:
the back panel is often a weak point
Interesting, I have suspected the same for the back of my dresser. Are there any recommendations on how to reinforce the back panel without affecting its appearance? I want to avoid it being visible or making changes that cannot be reversed later.
Also, I’m wondering if replacing the simple tension elements with sturdy metal brackets or reinforced screw connectors is worthwhile. Does anyone have experience with whether this actually results in noticeably greater stability overall?
dota57
15 Jun 2016 19:17
If you want to reinforce the back panel while maintaining the original look, I recommend screwing a thin plywood sheet on the inside. You can attach this invisibly through the open sides of the drawers. It’s important to secure the new fasteners with glue and make sure the screws don’t damage the front or outer edges.
Jaongi schrieb:
whether replacing the simple tension elements with sturdy metal brackets or reinforced screw fasteners is worth it
Yes, metal brackets make a difference, especially when it comes to stress at the corners. For wider dressers like Malm, this helps prevent warping. It’s worth investing in quality components here.
KINMIN4
16 Jun 2016 08:02
Always check the floor carefully. Often, simply attaching sturdy felt pads or small wooden blocks under the dresser can help prevent wobbling. Securing the joints with screws provides additional stability, but a solid footing is essential.
