I have several IKEA Malm dressers at home that I would like to make more stable because after some use they feel a bit wobbly, and the drawers are not as smooth to operate as they were initially. I am mainly interested in which mechanical or structural measures are effective to improve stability without significantly changing the appearance or functionality of the furniture.
I would also like to know if there are any recommended additional parts or reinforcements that can be installed discreetly, or if a complete replacement of the drawer slides and brackets would be more advisable.
Who has experience with Malm furniture or similar cabinet-type furniture and can offer tips on how to improve stability and durability in the long term? Thanks in advance for your input!
Hello faixfa,
First of all, well written and with a clear focus on stabilizing the Malm dressers! I can fully understand your thoughts on maintaining both the functional and visual integrity.
In general, furniture like the Malm is prone to wobbling due to the relatively thin panels and fasteners, especially if not placed on a perfectly level surface or if overloaded.
I recommend a step-by-step approach:
1. First, check all screw connections for tightness, including those often overlooked – the brackets at the back, the bottom supports, and the drawer slides. A loose part can quickly become a source of instability.
2. If you like, you can additionally attach small metal brackets to the back of the dresser. It is important that the brackets do not just secure the back panel but ensure a right angle. This significantly improves the rigidity of the cabinet. When positioning, make sure the attachments do not interfere with the drawer slides or mechanisms.
3. For the drawers themselves, it’s worth replacing or upgrading the runners. Original Malm rails are often plastic bearings that wear out over time. Replacement guides made of metal or even soft-close systems can greatly improve smoothness and fit, stabilizing the drawers.
4. A special option is to fix thin MDF or plywood strips to the inside of the cabinet sides to reinforce the side panels further. However, this requires more effort and precise measurements to avoid blocking the drawers.
5. Are the dressers standing on carpet or an uneven floor? A solid base, preferably a stable wooden board, can better distribute the load and stabilize the furniture.
I’m curious: Have you tried any of these measures already, or can you say something about the load or usage? Are the dressers heavily filled or rather lightly?
Good luck, and feel free to reach out with further questions!
Domau0 schrieb:
If you like, you can also attach small metal brackets to the back of the dresser.That’s a great tip that I often use as well. I would add that you should make sure to use rust-resistant brackets that can be securely screwed into the carcass without damaging the back panel.
Also, it doesn’t hurt—especially if the dresser is older—to reinforce the joints between the carcass panels with some wood glue. This helps permanently prevent small gaps and movement.
Regarding the material: For Malm and similar furniture, it’s important not to put too much stress on the fixing points, as the thin particleboard can chip. Therefore, it’s best to use thin but sturdy brackets and pre-drill the screw holes.
I would also add that you should avoid making any changes to visible surfaces unless necessary, to keep the overall appearance intact. If you prefer, you can attach the brackets on the inside, which is usually less noticeable.
Last but not least: A little maintenance for the drawer slides (e.g., some silicone spray on the runners) can significantly improve their operation.
Thanks for sharing your thoughts, Domau0 – this will surely make things clear and doable for faixfa 🙂
faixfa schrieb:
I am particularly interested in which mechanical or structural measures make sense to increase stability without significantly changing the appearance or functionality of the furniture.That is a very valid concern, especially with mass-produced furniture like Malm, where you want to maintain both stability and aesthetics. I will add to the previous recommendations:
You should pay special attention to reinforcing the back panel. Many Malm dressers have a thin hardboard back panel that is only nailed or stapled in place. If possible, securing it further with additional screws and appropriate washers will improve the overall resistance to twisting.
Another idea I often use for undersized furniture is to insert a thin aluminum or steel profile strip along edges that are prone to breaking or tipping. These inserts are effectively hidden and increase longitudinal strength without affecting the look.
Regarding the drawer slides:
Make sure to check not only that the rails run smoothly, but also that there is no damage or tear-out around the screws. If you find any, I recommend replacing them with high-quality full-extension slides or converting to ball-bearing slides. These are more durable and stabilize the drawer sides in all directions.
If you enjoy hands-on work, internal reinforcement of the shelves with crosswise wooden strips (for example, underneath) is also advisable. This prevents sagging under heavy loads.
Finally, a tip for assembly: Use fine-thread screws for the external panels to avoid unnecessarily weakening the material.
I hope this helps. Feel free to share how the furniture is being used or whether you have tried any disassembly or repairs yourself—this would help tailor the advice more specifically.
