ᐅ How can I make Malm furniture more durable?
Created on: 22 Oct 2015 08:43
nonmilor47
I own several Malm furniture pieces from IKEA, mostly dressers and nightstands, and I have noticed that after a few years of use, they tend to lose stability and the surface quality deteriorates. The edges and surface coating, in particular, seem to be vulnerable. My question is: How can I extend the lifespan of my Malm furniture so that they remain stable for as long as possible and the surface stays resistant to wear and scratches? Are there any special maintenance methods, protective measures, or small repair tips you would recommend? I am open to advice on proper cleaning, suitable materials for surface protection, or tips for careful handling.
lopra
23 Oct 2015 08:47
leomo schrieb:
Replace the protective film on surfaces from time to time
Exactly. It protects against scratches and is inexpensive to replace. You can also stick felt pads under the legs to prevent floor damage and wobbling.
GIPAPO
23 Oct 2015 12:03
For improved stability, it is worthwhile to tighten additional screws or even install angle brackets on heavily loaded furniture. This reinforces the joints and helps the piece remain sturdy for a longer time. This can be especially helpful with Malm.
nonmilor47
24 Oct 2015 06:59
dusujan schrieb:
that this furniture is affordable but not as durable as solid wood
That is an important point for me to keep in mind. So, it is a combination of careful maintenance and the construction properties that makes the difference. I will try using a lacquer pen and protective strips. Can someone also tell me which wax or care oil is specifically suitable for the often melamine-coated surfaces of Malm furniture?
TELAHAU
24 Oct 2015 08:15
nonmilor47 schrieb:
Which wax or care oil is specifically suitable for the often melamine-coated surfaces of Malm?
Regular wood wax is not suitable for melamine surfaces, as the coating is different from real wood. It’s best to use a gentle melamine cleaner and, if needed, furniture care products designed for laminated surfaces. Oils are generally not recommended. Alternatively, a furniture polish spray that also provides protective layers can be used.
