I am planning to gift a Malm piece of furniture to a friend but am unsure how to best adjust the "leg length" or dimensions. Since the Malm series offers various dressers and wardrobes with different widths and heights, I’m wondering if and how these pieces can be shortened or extended in a meaningful way to fit a specific room or space exactly.
My specific question is: How can Malm furniture be custom-sized in terms of length or width without compromising stability or design? Which modifications are realistic, and what tools or techniques are recommended? Are there any suggested procedures or modifications from Ikea itself for this kind of adjustment?
I look forward to tips, experiences, and maybe even small step-by-step guides.
Thanks in advance!
Thanks in advance!
Hello gaja49,
Regarding your question: "How can I customize MALM furniture in terms of length or width without compromising stability or design?" – this is a relatively complex issue because MALM models are built with prefabricated panels and joining techniques that are not necessarily designed for individual modifications.
Basically, shortening is easiest to do on the legs or the lower parts. For example, you can adjust the standing height by trimming the legs at the front or possibly replacing them with other base elements. You should ensure that the legs still provide enough stability and do not cause any wobbling.
If you want to change the width or depth, this is often more difficult. The panels are finished with edge banding, which makes cutting a bit challenging—you will need a fine-tooth saw with a clean cut or a circular saw with a suitable veneer blade, otherwise rough edges will result. In addition, you lose the pre-drilled hole and connection pattern, which affects assembly and stability.
It is also possible to have the top panel custom-made separately to replace the original – this is often the cleaner and visually better solution.
Tools I recommend, besides good power saws and miter guides, include surface glue for veneered cut edges and edge banding strips for refinishing. It is important to always keep an eye on the stability at the joints, which may require additional internal reinforcements.
Do you already have specific measurements in mind and want to reassemble the furniture after your adjustments? Or are you more interested in modifying or shortening it afterwards? This would help to better address your project.
A factual assessment regarding the general topic of adapting MALM furniture to specific room conditions:
MALM furniture is designed to be modular, but not modular in the sense that the width or length of individual components can be altered without compromising stability. The materials mostly consist of particleboard that is veneered and edged with banding. Structural modifications, such as shortening the side panels, inevitably reduce load-bearing capacity and can lead to instability.
I agree with this. One possible approach to adapting to spatial requirements is to replace the top panel with a custom-made, reinforced panel while retaining the basic structure. This allows precise sizing while maintaining stability.
Additionally, mechanical strength should be ensured by reinforcing the edges afterwards with wood inserts or angle brackets.
Summary:
- Shortening the legs for height adjustment is unproblematic
- Custom-made top panels replace to adjust width/depth
- No shortening of side panels without stability loss
- Caution with modifications to avoid voiding warranty and impairing function
INGRID34 schrieb:
Changing the width is problematic because it weakens the side panels.
Dilen schrieb:
You can also try having the top panel custom-made separately and use it as a replacement – this is often the cleanest and visually better solution.
Summary:
Hey gaja49!
Interesting topic – MALM furniture and custom lengths, that definitely gets exciting! 😉
I tried to customize my MALM a bit, and shortening the legs is definitely the easiest way if it’s just about the height. Cutting the side panels or top boards is more tricky and can easily go wrong – some of my friends have had real carpenter dramas with that.
If you want it truly custom, I’d consider getting professional cuts done for the top board (some lumber suppliers offer this), and leave the rest original – that way you have fewer stability concerns and don’t have to do any magic.
Also, if you’re planning to change any screw systems, IKEA sometimes uses special dowels and connectors that aren’t easy to replace. I found that out during my last repair project.
Good luck, looking forward to updates from you! 🙂
